Regular Suspension vs Sport Suspension
Like Tree5Likes
Old 26 Apr 2015, 04:24 am
KingBeach's Avatar
Default Regular Suspension vs Sport Suspension
Could anyone tell me what the differences between a regular suspension and the sport suspension is? I have a 06 Route 66 with the sport suspension , but my vin shows a Touring model which I'm not sure if the sport suspension was offered on. Is the entire suspension different or only certain pieces?
2006 PT Street Cruiser Route 66 Edition w/66k miles, 5-Speed, Pirelli P6's, RAQ 6-CD, BA 368w 6 speaker system w/Sub, 1 of 142 Route 66's with 5 speed manual.
Old 26 Apr 2015, 11:05 am
Default Re: Regular Suspension vs Sport Suspension
A decal
rob342 likes this.
Old 26 Apr 2015, 11:45 am
Like Nitro said, it's likely just a decal and there is no difference, but there is a slim chance you have the 26mm front sway bar instead of the 22mm or 24mm.
NitroPT likes this.
Old 26 Apr 2015, 01:08 pm
About 2 years ago this question came up because of all the different part numbers for the front as well the rear over the production years. I got several springs from different models and ran them on my spring LB tester. There was a difference in the convertible by 25ilbs compressed over a 04-06 GT and 01-03 NA -10lbs. less then GTs front only. This may have accounted for the 2 size option for the sway bar on GT and Convertible models? What ever the in between rating were I seriously doubt that there were any changes?
Oh , there may have been front strut shaft sizing difference but I never went so far as to check them. I confirmed the springs for my own personal information for a PT suspension project.
It may be of interest that the spring specification are not a common for PT Cruiser only and that many OE after market spring supplier have many springs that could be used with different spring rates. Even the Performance spring manufactures if you can get them to give you there spring specification and sizing information has many that could be used. As an example the set offered by Ebach is very conservative for general use of street driving even though they let you assume many sets are track rated. whatever that means? LOL
Its all about liability and the good word spread around about product. Heaven forbid that a real performance suspension be offered for "JOE AVERAGE" and they wreck their ride and blame it on the suspension upgrades. LOL
myckee likes this.
Old 26 Apr 2015, 07:26 pm
ya I only mentioned the 26mm sway bar because I was looking at trying to piece together a kit of bigger sway bars for my car. My car has a 24mm front bar. I was looking at an H&R kit. The H&R front bar is only 25mm and I knew some Pts had a 26mm. I would rather pay less for the 26mm Chrysler bar than more for a 1mm bigger bar than my current one. Anyway, when I looked up the 26mm bar, it is listed as for the sport suspension.
So it may be the sway bar that gives the car it's sport suspension designation or not was my reasoning.
Old 27 Apr 2015, 12:02 am
KingBeach's Avatar
Thank you all for the replys,I now know a little more than before. I had originally looked up shocks and struts and got so many different part numbers it got confusing. Below is my options sheet from Mopar Connect, as far as I can tell it has a sport suspension (no decal).......
Equipment Listing
VIN 3A8FY58B06T273840
Vehicle Description -2006 CHRYSLER PT CRUISER TOURING
Monotone Paint
120 Amp Alternator
510 Amp Maintenance Free Battery
Rear 65/35 Fold/Tumble/Remvble Seat
Frt Pass Forward Fold Flat Seat
Child Seat Anchor System-LATCH Ready
RR Head Restraints Outboard Seating
Advanced Multistage Front Air Bags
Passenger Compartment Floor Carpet
Cargo Compartment Carpet
Front & Rear Floor Mats
Front Door Sill Scuff Pads
Floor Console w/Covered Storage
Multi Position Shelf Panel
Interior Assist Handles
2.8 Overall Top Gear Ratio
Solar Control Glass
Rear Window Defroster
Rear View Day/Night Mirror
Sliding Sun Visors w/Illum Mirrors
Power Mirrors
Keyless Entry,Panic Alarm,2 Transmit
Rear Door Child Protection Locks
Sentry Key Theft Deterrent System
STANDARD EQUIPMENT
Air Conditioning
Deluxe Insulation Group
Instrument Panel
Instrument Cluster w/Tach
Instr. Panel Satin Silver Bezel
120 MPH Primary Speedometer
Tachometer
Analog Clock
Var Intermittent Windshield Wipers
Rear Window Wiper/Washer
Single Low Note Horn
12V Rear Auxiliary Power Outlet
Locking Glove Box
12V Front Auxiliary Power Outlet
12V Center Console Power Outlet
Power Accessory Delay
Speed Sensitive Power Locks
Pwr Windows, Front 1-Touch Down
SOLAR YELLOW BEZZEL
Illuminated Entry
Vehicle Information Center
Front Courtesy/Map Lamps
Front Dome Lamp
Cargo Compartment Lamp
Halogen Quad Headlamps
CHMSL Lamp
Backup Lamps
Security Alarm
Front Body Color Fascia
Front License Plate Bracket
Rear Body Color Fascia
Bright Door Handles
PT Cruiser Badge
Chrysler Wing Badge, Hood
Liftgate Chrysler Wing Badge
EVAP Control System
15 Gallon Fuel Tank
Solar Yellow Clear Coat
Fixed Long Mast Antenna
Power Rack and Pinion Steering
Front Stabilizer Bar
Tilt Steering Column
Compact Spare Tire
Occupant Classification System
-35F Protection Anti-Freeze
Front/Rear Climate Control Outlets
Build To U.S. Mkt. Specifications
GVW/Payload Rating
U.S. Dealer Retail
Zone 66-Orlando
Left Hand Drive (LHD)
Price Class P
Four Door
PT-Vehicle Family
Vehicle Order Tracking
U.S. Specifications Label
Florida Ship to State Code
Florida Sold to State Code
Cloth Low-Back Bucket Seats
Pastel Slate Gray
Boston Acoustics Audio Group
Traction Control
Anti-Lock 4-Wheel Disc Brakes
Manual Driver Lumbar Adjust
Supplemental Side Air Bags
Supplemental Frt Seat Side Air Bags
Front Bright Accent Ring Cupholders
Silver Shift Knob
5-Speed Manual T350 Transmission
All Gas Engine
2.4L I4 DOHC 16V SMPI Engine
Deep Tint Sunscreen Glass
Power Express Open Moonroof
Power 6-Way Driver Seat
Body Color Grille
Chrome Bodyside Molding
Street Cruiser Badge
Rear Bodycolor Spoiler
Route 66 Edition Badge
50 State Emissions
Federal Tier 2, Bin 5 Emissions
Bright Exhaust Tip
Power Steering Cooler
Speed Control
OPTIONAL EQUIPMENT
AM/FM CD 6-Disc MP3 Radio
6 Boston Acoustics Spkrs w/Subwoofer
368 Watt Amplifier
Sirius Satellite Radio
Leather Steering Wheel w/Brt Spokes
Sport Suspension
205/50R17XL BSW AS Perf Tires
Goodyear Brand Tires
17X7.0 Aluminum Chrome Wheels
Custom Painted Brake Calipers
Call SIRIUS to Activate@888-539-7474
Additional Subscription Fees Apply
1-Year Service Provided by SIRIUS
2 Additional Gallons of Gas
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Spring - Right Front
Customer Preferred Package 2DZ
Customer Preferred Package 27Z
Option Value
April Orders
May Orders
Test Order Tracking
Old 27 Apr 2015, 12:49 am
The H&R is a much better bar with a higher anti roll specification. You can not go by the size of a sway bar alone but also the design. If you are only comparing the factory sway bars naturally the larger diameter has a higher anti roll specification.
Old 27 Apr 2015, 04:47 pm
That's true, I didn't take into account the metallurgy. I wonder if anyone has tested the various stock Chrysler bars and even any aftermarket bars and compared them. I will do a search but I doubt the info is readily available outside of the manufacturers internal engineering specs.
Probably I will have no choice but to base it on size alone. We will see!
Old 27 Apr 2015, 05:01 pm
You're funny!
1 out of 1000 may know how to set up suspension to begin with, and you think anyone owning a PT Cruiser is going to do lateral G Data testing on a skid pad to compare sway bars?
I was actually referring to the hollow or solid and cold or heat bent.
Busted_PT likes this.
Old 27 Apr 2015, 06:02 pm
You're funny!
Haha well I was hoping you might be bored one day and go out and do some skid pad testing! lol
Actually I was thinking of testing more along the lines of how a spring is tested. Something like how many pounds of force to cause an inch of deflection. That way I could compare to see if the 25mm bar is delivering better results than the 26mm bar for example.
The Suspension wazzzzman General PT Cruiser Discussions 3 21 Sep 2008 06:46 pm
Sport suspension ???? bigpoppacat Wheels, Tires, Suspension 2 07 Sep 2005 01:26 pm
GT Suspension Better? 340x Turbo Wheels/Suspension/Handling 9 03 Jan 2005 02:03 pm
KW suspension lip Turbo Wheels/Suspension/Handling 19 24 Nov 2003 06:37 pm
Air suspension Ed Lim Wheels, Tires, Suspension 1 10 Sep 2003 05:13 pm
