Does Anyone Know if I can upsize tires on '08 Cruiser?
  • 1 Post By JoeX
Old 12 May 2015, 06:07 pm
Default Does Anyone Know if I can upsize tires on '08 Cruiser?
My '08 Cruiser is riding on the stock 195/65/R15 tires. I would like to change the tires to 205/70/R15s, which are a little over an inch bigger in diameter, to gain 1/2" of ground clearance and reduce cruising RPM's a little. Does anyone know if this will work without tire rubbing in full turns? Thanks.
2008 Base PT Cruiser 5-speed, 2008 Dodge Charger RT, 1997 Chevy K2500, 1979 Ford F-150, 2003 Harley Davidson Road King 100th Anniversary, Living Free in Montana!
Old 12 May 2015, 07:21 pm
Default Re: Does Anyone Know if I can upsize tires on '08 Cruiser?
I'd be more concerned about the tires rubbing the strut.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 13 May 2015, 08:35 am
Vlefaive's Avatar
This post has always helped me decide..
Maximum tire size
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
Old 13 May 2015, 12:10 pm
hi, I have a 2005 pt and changed from 195-65-15 to 205-65-15 to get more ground clearance and everything Is ok. no rubbing on struts and can make a full turn. jim hoysa
Old 20 May 2015, 12:05 pm
Thanks all. Jim, I was wondering if you typed the correct size for your replacement. Did you just increase width and not aspect ratio? Wouldn't the 195-65-15 and 205-65-15's have the same outer diameter, just different widths? I got to looking at current clearance between tire and strut and there is only about 3/4" with well-worn tires, so a tire about 5/8" greater in radius would get very close to strut. At this point, I am leaning toward sticking with the stock size. Sam's Club has agreed to try the 205/70/15s on for size before I buy, so I may do that rather than ordering from Discount Tire Direct. In no hurry, just need new tires before winter. Thanks!
Doug
Old 20 May 2015, 12:19 pm
Jim, disregard my last, I got to thinking if you increased width with the same aspect ratio, you also increased diameter - by just over 1/2" in your case! I do believe I could safely do the same on my PT. Thanks, this is just the answer I was looking for. Only increases ground clearance by about 1/4", but helps none-the-less!
Doug
Need advice on tires, just bought cruiser lisesheehan Wheels, Tires, Suspension 6 23 Aug 2014 07:10 pm
Tires for Dream Cruiser??? StealthyK Wheels, Tires, Suspension 4 13 Aug 2011 09:12 pm
Will 225 tires fit 2001 Cruiser PTAjax Tech & Performance Forum 10 17 Dec 2009 10:26 am
PT Cruiser Tires oscar514 General PT Cruiser Discussions 23 15 Oct 2009 10:14 am
Pt Cruiser Wheels and Tires Arkansas 340x Classifieds: For Sale/Trade 1 09 Jul 2009 02:41 pm
