'01 Rear Hubs: Need some tips
Old 20 May 2015, 10:13 pm
pmcruiser's Avatar
Default '01 Rear Hubs: Need some tips
I am going to be replacing both rear hubs on my '01 N/A with rear disc brakes. I found the following instructions (below). Anybody have any pics, tips or anything to help to go along with the instructions below?
Instructions
  1. Raise and support the rear of the vehicle on jack stands. Remove the rear wheels using the ˝-inch air gun and a socket.
  2. Remove the brake caliper by removing the two bolts holding the caliper to the mounting bracket using the 3/8-inch ratchet and a socket. Pull the rotor off the hub.
  3. Remove the torque strut. This is the rod forward of the hub and is attached to the frame and the hub. Use the 3/8-inch ratchet and socket and remove the bolt at the hub. Remove the nut on the lower ball joint with a wrench.
  4. Separate the hub from the lower control arm by inserting the ball joint and tie rod end remover tool between the hub and the lower control arm. Strike the tool with a hammer until the ball joint separates from the control arm.
  5. Remove the two large bolts and nuts holding the strut to the hub assembly using the 3/8-inch ratchet and socket on one end and a wrench on the other. Take the hub assembly to a machine shop or other facility to have the bearing pressed out and in.
  6. Replace parts in reverse order of removal.
2001 LE 2.4L N/A
5 Speed Manual | Borla S/S Dual Exhaust | K&N Drop-in Filter
CarDomain Page
http://www.cardomain.com/ride/392318...sport-wagon-4d
Old 21 May 2015, 05:29 pm
Default Re: '01 Rear Hubs: Need some tips
Instructions
In your instructions, only the first 2 instructions pertain to the rear. Instructions 3-6 are actually referring to the front hubs.
I think Handy_Cruiser did a 'how to' on how to replace the rear hubs and bearings. It is actually 'stickied' and one of the first links on this forum. Anyway here is a link:
The Handy Rear Wheel Bearing Change Out
Old 21 May 2015, 05:42 pm
Those instructions don't even make compleat sence. Just do like mychkee said. Sounds like you want to convert to disc brakes from drum brakes.
Old 22 May 2015, 08:47 am
pmcruiser's Avatar
Thanks guys for the help! I looked through The Handy Rear Wheel Bearing Change Out link provided and it looks look the rear hubs don't have to be pressed out and then pressed in like the fronts... they just slide right off the axle.
I found a youtube video (below) on how to replace the rear hub on a 2000 to 2005 Neon which I ASSUME is more or less the same principal.
Gonna pick up the new hubs and a 30mm" socket and swap 'em out. Looks pretty straight forward.
2001 LE 2.4L N/A
CarDomain Page
Old 22 May 2015, 08:59 am
Neon is a compleatly different animal. That's why we didn't reconize the procedure. So you just want to replace the rear bearing hub and brake pads. Sounded like you were wanting a drum to disk conversion.
Old 22 May 2015, 09:15 am
Handy_Cruiser's Avatar
Yeah. The rear hubs will just pull off by hand once the spindle nut is removed. No special tools or pullers are required:
And hey, consider going for rear disc breaks. Here's my thread on that:
The Handy Rear Disc Brake Upgrade
Old 22 May 2015, 09:26 am
pmcruiser's Avatar
Sorry for the confusion. Yes, I just want to replace the rear bearing hubs. No disc brake conversion, I already have rear disc brakes.
The link was very helpful. Says there is a 30mm nut on each side to remove the rear hubs. Can't get more simpler than that (thank goodness).
Thanks everybody and especially Handy_Cruiser for the great write up!
2001 LE 2.4L N/A
CarDomain Page
Old 22 May 2015, 09:29 am
pmcruiser's Avatar
That's awesome news! Thanks again for the awesome write up! Oh and somehow I messed this thread up... I have rear disc brakes already lol
Cheers guys!
2001 LE 2.4L N/A
CarDomain Page
Old 22 May 2015, 12:18 pm
pmcruiser's Avatar
Crap! Went to order and see that they come with either Slotted Type Tone Ring or with Gear Type Tone Ring.
Anybody know which ones I need for Rear Disc brakes WITH Anti-Lock?????
2001 LE 2.4L N/A
CarDomain Page
Old 22 May 2015, 01:30 pm
Should be gear type. It should specify for antilock brake on the one you need.
2004---Changing front Hubs/wheel bearings jdsausville General PT Cruiser Discussions 1 23 Nov 2013 05:03 pm
2002 Dream Cruiser Center Hubs for sale CJJU Classifieds: For Sale/Trade 1 16 Apr 2012 12:26 pm
NEW HUBS ALBERT Feedback and Support 4 28 Jan 2012 06:16 pm
rear drums rusted on hubs Carl48 Tech & Performance Forum 1 03 May 2010 04:56 pm
Jan/ tips/ vol 1 turbomangt The Detail Shop 4 05 Jan 2004 09:48 am
