So I had my front brakes down about 5k miles ago. Had to get them done twice thanks to a bad rotor the first go around..That said, I only commute about literally 5miles to work each day, so its hard to gauge issues as they arise. Lately I've noticed that when I brake HARD i can hear what "sounds" like my rear rotor spinning? Its definitely a circular sound dependent upon my speed, and only occurs when I apply significant brake pressure, so I'm assuming my rear brakes/rotors are bad? I brought it up at work and everyone told me to look into the wheel bearings, but pretty sure it has to be the rotor at this point?
Fairly uneducated with vehicles so seeking some insight before I go tear the wheel off and what I should be looking for/expecting. Any feedback is appreciated. |
I would suggest you check your rear brake pads or rotors being warped. If the brake pads are worn out you would hear a metal to metal rubbing with the rotor contacting the metal of the pad. You need to check this immediately or you could possibly be damaging more than just the rotors.
The shoes for the hand brake are inside the rotor hat. Requiring you to remove the rotor to get to them.
I didn't even think about the E-brake--which is definitely bad because when its on and I get outta the car I can hear the death noise of it(live on a hill). I was assuming it was the rear pads but stupid question, could this be causing an issue when braking not in reverse, wouldn't that come from the front pads not rear?
Which is where my concern is because i JUST did the front brakes/rotors like 6months ago and put maybe 1,000 miles on the car since then. There is no metal grinding, it simply is an oscillating sounding noise dependent upon heavy braking, and from going to work today and back again, it only happens once it is heated up it seems. I will have to take it to Midas or something as I don't have the time but wanted to be aware before i get possibly scammed. As far as I know, the E-brake was never changed and the car has 126k miles. Thanks~ |
![]() Quote:
![]() Quote:
Tags |
brakes, rotor |
Thread Tools | |
Display Modes | |
Need some help diagnosing a small issue | Ckozizzle | Tech & Performance Forum | 19 | 08 Nov 2014 10:16 am |
clicking noise from rear brake revisited | rotty | Tech & Performance Forum | 1 | 21 Mar 2014 01:41 am |
Diagnosing sputtering start / shaking while idle | q1h | Tech & Performance Forum | 5 | 14 May 2012 08:26 pm |
Odd Brake Noise | ChicaLinda | Wheels, Tires, Suspension | 1 | 10 Oct 2011 03:05 pm |
Rear brake noise... | Striker | Wheels, Tires, Suspension | 4 | 04 Jun 2006 12:01 pm |
