Rear Brakes Issue
Old 24 Jun 2015, 11:26 am
Default Rear Brakes Issue
Hello, name's Damien. New to the forum.
I have a 2004 PT Cruiser Touring Edition, 2.4L Turbo 124000km from a chrysler used car lot.
*Car has Drums*
Lately, everytime I start the car and take off, there is a god awful squealing noise coming from the back when I brake, BUT only for the first few brake applications. Once I leave the parking lot and hit the first two stop signs within 40ft of my house the brakes are silent the entire time I use the car. I bring it home and it sits for maybe 6 hours and when I take off, the squealing comes back, but only for that short distance. Only other thing I've noticed is when I come to a complete stop after driving for a while, there is a very very soft grinding noise with a metallic tinging noise(almost like a spring) right before the car stops . I'm pretty knowledgeable with cars but I'm wondering if anyone else has had this issue because I'm stumped. However,
-The rear shoes are brand new( Everything was installed by the dealer when I bought it)
-I have no decrease in braking power at any time
I took off the drums to investigate, and the only thing that didn't seem right was despite the rear brakes being disengaged, I literally had to pry the drums off with a screwdriver. Almost as if they were partly or fully engaged.
Could there maybe be a cylinder going, causing the shoes to be partly expanded enough they rub on the drum? or something worse.
Any help would be appreciated, The car runs and performs well, its just annoying having the whole neighborhood watching me pull out
thanks
Damien
Old 24 Jun 2015, 03:38 pm
LionPT's Avatar
Default Re: Rear Brakes Issue
*Car has Drums*
thanks
Damien
If the brakes are adjusted properly they shouldn't just slid off...but don't just pry them off either, use the adjuster in the back to loosen the brake shoes.
Besides taking the car back to have the brakes checked...put the car in reverse & stomp the brakes about a dozen times...this should reset the adjusters. It might or might not work, but it's worth a try.
Old 24 Jun 2015, 04:11 pm
rcktpwrd's Avatar
when the brake shoes were replaced did they resurface or replace the drums as well?
I would bring it back and let the dealer have a look if it's still under warranty...
Joel
www.rcktpwrd.com
rear brakes jdmickies Tech & Performance Forum 2 14 Dec 2010 10:00 pm
Rear Brakes garyerrol Tech & Performance Forum 1 01 May 2009 07:34 pm
Rear Brakes wazzzzman Tech & Performance Forum 7 09 Oct 2008 04:42 pm
rear brakes robin Wheels, Tires, Suspension 2 19 Mar 2007 09:13 am
GT rear brakes OurPTGT General Turbo Discussions 4 30 Oct 2003 03:56 pm
