Front Brakes, Grinding Noise
Old 30 Jun 2015, 09:46 pm
Default Front Brakes, Grinding Noise
Hey, Whats up?
I have been hearing this grinding noise when ever I brake from high speed (60-100k/m), and some time from low speeds like (25-30km/h) to a complete stop. I thought it was my brakes warning me the brake bads are going bad, but I've changed them. So I went to the store yesterday and bought pads and rotors, and when I took a part the calipers, the brake pads that were on the brake were in good condition, they had a lot of life left in them (60-70% left).
So i'm going to return the pads and the rotors, and I can't figure out which might be causing this? (control arm, bush....)
Thanks for reading, cheers.
Old 30 Jun 2015, 11:06 pm
Default Re: Front Brakes, Grinding Noise
I would suggest you check to see if there is a ridge on the edge of the rotor disks themselves. If it is too high then it will grind. If there is a ridge you need to measure the rotors and see if they are worn down to the point where they need replacement for safety. Check both sides of the rotor disks.
If there is no ridge then I would suggest you check the calipers. You may need to clean the calipers if they are not sliding correctly.
AC Fan grinding noise shonenknife Tech & Performance Forum 6 27 Jun 2013 05:59 pm
Grinding noise while slowing down, whirring noise while speeding up thedarkcanuck Tech & Performance Forum 5 27 Nov 2011 10:15 am
Grinding noise. PtOnAir Tech & Performance Forum 6 10 Jan 2011 09:40 am
grinding sound coming from brakes timberghost159 Tech & Performance Forum 8 24 May 2010 11:43 am
Grinding noise front end 2002 woody Art Rigby Tech & Performance Forum 1 29 Oct 2009 07:05 pm
