Wheel spacers
Like Tree2Likes
  • 1 Post By rob342
  • 1 Post By ptcru1s3r
Old 03 Sep 2015, 04:30 pm
whiteclaw's Avatar
Default Wheel spacers
So i was fitting my new wheels, bought ones which required no alterations to the car, however, it seems the back ones are fine but the front ones caught on the calliper.
The calliper on the front sticks right out and so I havent the clearance.
Any idea what spacers I should be getting?
I got it that my wheels are 5x100 spacing, but there seems to be all sorts out there on the net.
Chrysler PT Cruiser 2001, Automatic, No Mods, Right hand drive. 2.0
Old 03 Sep 2015, 04:45 pm
Default Re: Wheel spacers
is it close enough you can just grind the caliper a little?
it's not uncommon, and after a coat of paint you'd never know.
https://www.google.com/search?q=grin...ih=595&dpr=1.3
j0e likes this.
Old 03 Sep 2015, 05:44 pm
whiteclaw's Avatar
It's a few mm, horrible sound due to my foolish error. Resprayed the front wheels again.
Reluctant to use spacers as i fear it would set the wheel beyond the fender which means i get pulled over by the coppers.
Saw loads online different mm thickness etc but none mention the diameter.
Old 04 Sep 2015, 06:48 am
ptcru1s3r's Avatar
You need to use 5mm spacers. Assuming that the wheels are 16" diameter or larger, they should not foul the caliper.
I have 20mm spacers with 6.5 inch wide wheels and they sit at least an inch inside the wheel arch. At the rear I have 30mm spacers and they sit flush with the bodywork.
How much yours stick out depends on the width of your wheels, assuming that they have positive offset.
JoeX likes this.
test
Wheel spacers davea300 Wheels, Tires, Suspension 5 28 Oct 2012 02:53 pm
wheel spacers? jrbsr05pt Wheels, Tires, Suspension 11 10 Mar 2012 08:54 pm
Do I need wheel spacers? yellowruby Wheels, Tires, Suspension 2 22 Feb 2009 05:54 pm
Wheel Spacers Brian Hale Tech & Performance Forum 5 20 Apr 2008 02:01 pm
Wheel Spacers erwinlg Tech & Performance Forum 2 08 Apr 2003 11:15 am
