PT Cruiser Forum Car Videos
Car Rims
Control Arm Bushing
Old 19 May 2004, 07:25 am
PTZCrazy PTZCrazy is offline
Send a message via AIM to PTZCrazy
Default Control Arm Bushing
I had an oil change at a local service center. The mechanic advised me that the lower control arm bushings are distorted and coming out of the metal sleeves. the control arms are an integral part of the front suspension. I arranged for a Chrysler dealer to determine the status of the bushings. They agred that they were defective. Supprisingly Chrysler replaced the entire control arms at no cost since my PT was still under warranty. Apparently the busing is presed in to the control arm and can't be repaired. They did not indicate if the bushing are a chronic problem, but it may be worthwhile to ahve them checked at your next oil change. This is one of those IF YOU DON'T NOTICE IT, THEY AREN'T GOING TO TELL YOU. Extra side benefits include an improved ride, and they did a free front end alignment. Don't wait until it's too late, check them yourself, or have someone check them that has knowledge of the lower control arms. Your costm if YOU have to foot the bill can be upwards of 350.00 to 400.00.....
Old 19 May 2004, 09:33 am
The UK PT site has lots of posts about bad "bushes". I guess I have to have mine checked out, too. I thought there was a way to get better bushings - urethane - RallyDRock did it. [:I]
Old 19 May 2004, 10:43 am
yeh i popped those in on new ywars day in my driveway.
took about an hour per side. I didnt have a press at home then so i burned the bushings and pushed them out with a stick. big difference and the new ones will never go bad, much better design and material.
Old 19 May 2004, 01:28 pm
clevelandmike clevelandmike is offline
PTC>>>I don't know where you live but your bushing statement apppears to be a word-for-word duplication of my insert in the North Coast PT Cruiser newsletter (Ohio). No complaint, just curious if you agree.
Old 20 May 2004, 12:01 pm
PTZCrazy
Old 20 May 2004, 12:03 pm
You hit the NAIL on the HEAD, but it was something that happened to me, YES, here in oHIo.
PTZCrazy
Old 08 Jun 2004, 02:42 pm
jmack jmack is offline
Send a message via AIM to jmack
But what about a Popping Noise? Mine needs those replaced and they said that it would alleviate the popping noise that my car has been making. It seems to do this when I am making sharp turns where the car is on uneven ground (going through turn lights, hills, etc)
About to start work on modding my car and making it look even better than it already is!
vB code is On
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 18 09 Jan 2008 01:14 pm
Front Control Arm Bushing Question JohnM Wheels, Tires, Suspension 6 26 Aug 2005 11:40 am
obd-II codes Punch General Turbo Discussions 5 06 Nov 2003 02:34 pm
  Loans | Web directory | Gourmet Chocolate Assortments | Car Credit | Guitar Books
