Is my rear sway bar including the rear away bar install kit?
Old 12 Oct 2015, 01:13 pm
Default Is my rear sway bar including the rear away bar install kit?
I was informed that I am missing the end links. What is the black thing attached to the bar then? I see many different kinds of end links online so I don't know which style the pt cruiser uses.
I'd just like conformation before dropping $200 on an installation kit.
Pictures found below
funkyfred16's albums - Imgur
--2006 pt cruiser non turbo owner. Completely stock... For now.
Old 12 Oct 2015, 01:17 pm
Default Re: Is my rear sway bar including the rear away bar install kit?
Those are the end links. It appears you have all the items needed!
My cell phone only opened the first picture but my PC opened all the pictures!
This is the only picture I saw at the time.
You should be good to go. It is a simple installation with common everyday garage tools.
Old 12 Oct 2015, 01:29 pm
This is my happy face!!! Woooo!!!
I'm going to indulge in that herb to fight with you later lol. Thanks again nitro. I'll be taking pics when I open the door panels again for the sound deadening. You're looking for tricks on how to do it yourself next time right? It's fairly easy. Let me know if you ever want an answer before I install the new speakers.
Now I wonder which of the rubber things I should have replaced. They might be worn out. Can I buy only the rubber parts? I know the 24-26mm grommet is available on rockauto.. But what about the rubber in the end links?
Old 12 Oct 2015, 01:37 pm
End links as they look on the PT cruiser
Yes I know it is dirty again, but we did take the PT off road this weekend!
Old 12 Oct 2015, 01:39 pm
All the bushings are available from several sources.
Old 12 Oct 2015, 01:45 pm
Here is a set of rear end link I was custom fabricating or assembled depending on what you want to call it? In this case I simply ordered separate components none suspension related and made them work as suspension components. Nothing special here but 1/3 the cost of anything available and I will be using top quality spherical rod ends.
Old 12 Oct 2015, 05:22 pm
The stock rear sway bar links probably should be replaced as they will make noise if the are worn enough, not always visible.
That Eibach bar is much larger than the stock sway bar like my son and I installed on our 03s. The stock bar makes a big difference over no bars though.
We have not yet found any of the aftermarket improved suspension parts in our trips to the pickyourpart yards.
Old 10 Nov 2015, 09:19 am
^^^ what^^^ can you translate into English??
Old 10 Nov 2015, 10:02 am
Handy_Cruiser's Avatar
I went with the polyurethane bushings. There were easy to install, worry free and no noise. The bump stop is nice too. It's fairly soft and does a good job with a load in the back. This all looks good too
Old 10 Nov 2015, 10:34 am
The noise will eventually rear its ugly head...but then you NO LONGER own this PT Cruiser so you don't have to worry.
I just think that others should be aware that polyurethane bushing are hard to keep "noise free".
The other thing is the bumps stops available from as far as I know which include the worldwide market are a harder rated bushing then what comes OEM. So this is another reason why NOT to use them unless you just like the colors!
03TXPTGT likes this.
Eibach Rear Sway Bar Install Kit SteelBlueGT Turbo Wheels/Suspension/Handling 3 15 Jul 2006 01:54 pm
Rear sway bar install where none exists now snakepitt1 Tech & Performance Forum 2 14 Jul 2004 12:34 pm
Rear anti-sway bar install on GT JohnM General PT Cruiser Discussions 11 24 Jul 2003 07:38 pm
Rear Sway Install Problem divots Turbo Wheels/Suspension/Handling 6 06 Jul 2003 01:57 pm
Need instructions for rear sway-bar install hyracer Turbo Wheels/Suspension/Handling 6 14 Jun 2003 09:44 am
