Ball Joint Pinch Bolt
Old 16 Oct 2015, 09:01 am
Default Ball Joint Pinch Bolt
So, my PT has the clunk from the front end. The LCA bushings are good. Sway links and bushings are good. I checked and had a mechanic check and every thing looks and feels tight. So, I had the drivers side ball joint pinch bolt replaced. Long story about why... But the new bolt solved the clunk. But now I need one for the passenger side. The shop doesn't have one. Can anyone tell me where I can get that bolt? It comes with the ball joint but I just need the bolt.
Old 16 Oct 2015, 09:29 am
Default Re: Ball Joint Pinch Bolt
part #24 and #25 in the diagram here
nut:
NUT, NUT AND WASHER. Mounting, Shock Absorber Lower Mounting. M12x1.75 made by Mopar. #06501247
bolt:
BOLT. Hex Flange Head. M12x1.75x57 made by Mopar. #06501248
i would print both and head to the dealer. if prices were more than double, i'd order it online.
you can get a ball joint with the bolt for $4.89 from rock auto. with shipping it's $12 total. may be less for you, depending on your location
Old 16 Oct 2015, 08:51 pm
Thanks Rob!!!!
Ball joint replacement Tobymelodeon Wheels, Tires, Suspension 2 22 Apr 2013 12:21 am
Ball joint dust boots? chuck2112 Tech & Performance Forum 2 06 Feb 2010 09:17 pm
Help with Ball Joint Mrz Wheels, Tires, Suspension 3 30 Mar 2009 06:57 pm
Ball Joint Replacement: Still having problems CarMah Wheels, Tires, Suspension 2 11 Jun 2008 09:07 pm
Bad ball joint replacement? Samson Wheels, Tires, Suspension 4 19 May 2008 05:40 pm
