2004 PT Cruiser front end clunking over bumps
Old 25 Jan 2016, 06:31 pm
Default 2004 PT Cruiser front end clunking over bumps
My 04 PT cruiser is clunking in the front end suspension, now we replaced control arms, inner and outer tie rods, all ball joints, and cv axles on both sides myself got all the info from the book, the only thing that puzzles me is that before we removed the old cv axles we moved the shaft in and out and there was play in the shaft between the transmission and the tire, I read that if there is play in the shaft that they should be replaced so we replaced them and when we got everything back together and I tried moving the new cv axle shaft it still moved the same amount of play as the old ones did, so because we have 2 PT's I went over to the other PT and tried moving those cv axles on that one they didn't move at all and with that car we don't hear any clunking on that car like we do with mine. I talked to a guy at our autozone and he said that there is supposed to me a little play in them, so I don't know who to believe and what went wrong with the ones I put on, I'm pretty sure that the cv axles are the things that are clunking when we hit bumps because I checked everything else again and it's all still tight and looking good yet so please if you might have an idea please let me hear it anything is a plus for me at this point, I'm still driving the car praying nothing happens while driving it the bolts at the tire hub for the cv axle are good and tight too still are.
Old 26 Jan 2016, 09:37 am
Default Re: 2004 PT Cruiser front end clunking over bumps
Could be the strut mount bearings.
Hey, hey I wanna be a rock star.
Old 26 Jan 2016, 01:28 pm
Check the rubber bushings on the front sway bar which cushion the bar under the floor. The Woodie I recently had clunked on bumps. It was the bar hitting the floor.
Old 26 Jan 2016, 01:32 pm
But it sounds like it's coming from the bottom of the suspension area it don't sound like coming from the upper strut area.. But thanks for helping, sorry I didn't put this info on here before.
Old 26 Jan 2016, 04:00 pm
Well, if you feel it in your feet, the I'm going to have to agree with pasadena on this one. Check those sway bar bushings.
Old 08 Mar 2018, 09:25 pm
I have a 2003 with 198000 miles. In tracking down rattles after replacing the shocks/struts, found the drivers side cv shaft has at least 1/32" axial play, which is causing the rattles. The passenger side is fine. I'm thinking of shimming between the CV and the hub to reduce the clearance. Anyone have any thoughts?
Noise when I go over bumps in the front ew55 Wheels, Tires, Suspension 10 09 Nov 2014 07:00 pm
Front End Noise on Bumps jim572d Turbo Wheels/Suspension/Handling 10 25 Jul 2013 07:34 am
Clunking noise in front RoseDust Tech & Performance Forum 4 19 Sep 2011 10:21 pm
My front end sqeaks when I go over bumps lilooetruiser Wheels, Tires, Suspension 2 02 Dec 2009 07:23 pm
2001 Metallic clunking in rear on bumps harleysforfun Wheels, Tires, Suspension 5 16 Jan 2007 11:24 am
