I have a roar in the right front of my 03. it gets louder the faster I go. when i turn right it gets quieter, and when i turn left it gets louder. I replaced the right front bearing and nothing changed. swapped front and back tires and it got a little quieter but not much. checked the camber the best i could and both fronts seem to have a slight but equal negative camber. any suggestions.
I experienced the exact same noise and made an incorrect diagnosis. I correctly diagnosed it as the wheel bearing, but found it to be the opposite side of what I "thought" the noise was coming. Hard left turns increased the roaring noise coming from the right wheel bearing. I've replaced that particular bearing 3 times in the matter of 10-15k miles. Next go round (which it needs to be replaced as we speak), will be from the factory and not aftermarket.
**2005 PT Cruiser Touring Convertible Turbo - 20x8" Milani Wheels 245/35 & 225/30, air ride & more. Build Thread: http://www.ptcruiserlinks.com/forum/...ser-turbo.html **2008 PT Cruiser **2007 Chevy HHR LS - Transition to LT - 18" Solstice Wheels 235/45 & 225/45 [IMG][/IMG] |
Change The other wheel bearing. That will fix it. When I replace these. I add grease between the two inner races of the bearing. Have to use your fingers to work it into the crack. But I belove this give me a better lasting bearing. I think that they might not have as much as they should. Maybe that is why some have repeated replacement. Will have to see over time.
tell us more
I have a 2006 convertible Automatic Tranny with a rhs growl noise as well. Turn left it gets louder turn right it gets quieter. Changed RHS wheel bearing and the problem is still there. Wondering if I should look at Drive axle. Tranny Output bearing????? Please help with a little guidance. Thanks Everyone!
Hey Rob Thanks.
So you suggest changing the Left wheel bearing then. That fixed it on yours? I thought that if I turned Left it would cause more outer pressure on right whell so that is why I changed the right bearing. |
Thread Tools | |
Display Modes | |
Help please! Passenger front front seat back rest wobbly | Feld | PT Cruiser Videos | 1 | 24 Mar 2015 01:41 am |
Roar in left front | goverfelt | Tech & Performance Forum | 7 | 18 Mar 2014 07:36 am |
Loud Engine Noise - Roar | migrainemotor | Tech & Performance Forum | 3 | 13 Dec 2013 10:02 am |
Roar in Front End | PT_or_not_PT | General Turbo Discussions | 11 | 08 Aug 2013 07:08 am |
Tire Roar | ozz114 | Wheels, Tires, Suspension | 7 | 22 Apr 2013 07:14 am |
