Front tires wearing out sooner
Old 11 Jun 2004, 02:07 am
Default Front tires wearing out sooner
Hey I only have 13,500 miles on my PT, and it looks like the front tires are wearing out about 1/3 more than the back. especially around the outside edges. I don't speed around corners. Has anyone else had the same problem. Is it the weight of front end? How many miles can one expect to get out of those good year tires. [:I]
Old 11 Jun 2004, 03:21 am
do you rotate,you should rotate your tires every
6000 miles front to rear. I change tires in winter so
I rotate than.
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
Old 11 Jun 2004, 10:42 am
It's completely normal for fronts to wear faster on a front drive car - in fact, you can probably replace the fronts and the rears will still be good, which is what I usually do, but the Good-for-a-years I disliked so much, I rotated and replaced all 4 with Michelins which aren't made with eraser rubber.
Old 11 Jun 2004, 10:50 am
You have all the weight of the engine and transaxle over the front wheels. 60% of the weight shifts to the front when you brake. The front wheels do all the steering. Not only can you expect the front tires to wear out 2 to 3 times faster than the rears, your front brakes will be the next thing to go. Choices: Don't rotate and you'll only have to buy 2 tires at a time. Rotate and your tires will last twice as long but you'll need to replace all 4 at one time. [:I]
Old 11 Jun 2004, 11:25 am
wear on outer edges, increase air pressure a little bit.
Old 11 Jun 2004, 03:55 pm
[8D]Thanks for the good Info. I'm haveing them rotated today. I didn't know that about rotateing the tires at 6,000, I bought the car used at 8,500 miles should have had it done then.
I like that "Good for a Year" I have to agree I think Michellen or Brigston's much better. After I seen the front tires, I also thought about the front brakes how long do those last?
I also am having CD check the hose problems, although the service manager said that's not a problem with this car. I asked them to put a clip on the one issue, and check the other one we've been reading about. I showed them the articel from web site and pic's, and mentioned I got a call from in law in CA about the problem in local paper. I would pay for it just want peace of mind. They said they haven't heard of the recall yet. And they do what they can but when I do get a recall they call it in an do according to procedure. Sounds reasonable.
Help! Badyear tires strike again! SRG General PT Cruiser Discussions 40 20 Apr 2009 10:27 pm
FS: HUGE Wheels and Tires Lot ptcruzin42 Classifieds: For Sale/Trade 4 06 Jun 2006 10:41 pm
New Tires DestroyerMD Wheels, Tires, Suspension 4 23 Jul 2005 11:27 am
Replacing front tires - stick with H rating? coolvirus Wheels, Tires, Suspension 10 17 Feb 2005 05:54 pm
Compare tires on rims. KingKole02 Wheels, Tires, Suspension 6 15 Apr 2004 09:31 am
