Approaching 30,000 miles on my '02.Thinking about replacing the original rotors (some crticize for being too thin) with after market
slotted/drilled rotors and also adding cleaner running ceramic pads. Are the aftermarket rotors better? Cost? Suppliers? |
Aftermarket rotors will not be any thicker than the OEM, but the metalurgy can be much better.
The OEM rotors are made in Mexico, while cheapo replacements are Chinese. The Canadian top-shelf rotors are all I use. I've installed several dozen PT rotors fromm NAPA. The AE-86955 @ $56.00 each is my choice. |
I have not used them, but i hear that drilled rotors are
good for romoving heat. Slotted rotors "slice" your brakes away. I believe using the slotted rotors, you will see that you are going through brake pads quicker. |
Don't know about rotor rust.
All my brake jobs get the rotors coated with a pre-installation treatment called Squeak-Relief(tm). This coating is silver metallic colored and does not promote surface rust. Remember, all new rotors MUST be washed and cleaned of shipping oils prior to installation. This coating, along with proper break-in and quality parts is the answer to quiet braking. |
What is the proper break in of new rotors and what do you use to clean the new rotors??
04 cool vanila Limited Turbo ![]() Wife has a 03 limited (Steel Blue) |
Soap and water is the ONLY recommended prep for new rotors.
Brake cleaner is used by many others, but is NOT the best method. Make 10 stops from 35-40mph to zero with moderate braking pressure. You will get a distinct smell of hot brakes in only 10 moderate stops. This seats the pads and rotors. These instructions can be found directly from the brake manufacurers. It's not just an opinion, it's the printed method from the makes. |
| parking brake light going on??? | yobiebs | Tech & Performance Forum | 8 | 01 Nov 2007 09:25 am |
| Parking Brake Light upon Acceleration | JohnM | Tech & Performance Forum | 5 | 27 Jan 2006 09:07 am |
| Brake kits for the Pt Gt from Moparsupercenter.com | JEFF@RHJEEP | Vendors & Buyers Forum | 0 | 23 Apr 2005 01:07 pm |
| Parking brake light coming on | CHROMEDCRUISER | Tech & Performance Forum | 8 | 06 Dec 2004 10:11 pm |
| Aftermarket brake pads | MEXICANPT | Turbo Wheels/Suspension/Handling | 9 | 19 Dec 2003 06:31 pm |
