Grab your lug nuts
Like Tree2Likes
  • 2 Post By Fk5
Old 20 Mar 2017, 11:42 am
Default Grab your lug nuts
I have a 2004 with 365,000klms or approximately 200,000 miles
Yes, it is still going strong. Here is my question....
I have factory chrome rims.
Basically, they are an aluminum rim
with a plastic chrome dressing permanently attached.
Each wheel is mounted with 4 - 19 mm lug nuts
and 0ne lug nut slightly smaller with a removable sleeve .
Does anyone else have this...?
Or
Is anyone out there familiar with this...?
Old 20 Mar 2017, 12:01 pm
Default Re: Grab your lug nuts
Welcome to the forum. Are you in the U.S.? All U.S. PT Cruisers came with 5 lugs on each wheel (5 X 100). Should I move your post over to the European side of the forum?
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 20 Mar 2017, 12:45 pm
Fk5 Fk5 is offline
All your lug nuts are probably like that. Just one "sleeve" came off. I have had the same problem with mine. You can usually use an 18mm on them if the cover is off. Either that or the larger ones are aftermarket.
This is a 300, but same basic thing:
rockandroller and JDK52 like this.
2003 GT 5 speed
162,000 miles
Old 20 Mar 2017, 02:10 pm
VsandFords's Avatar
Welcome to the forum from Texas. Is it possible that the smaller lug nut is a "locking" nut? If so, they usually take a special socket/tool to remove. If you recently purchased it, check the glove box and see if the tool is in there. You might check both compartments in the cargo area also.
It might be good to see a picture of them.
Grab Handles fogerty Interior Accessories Forum 15 17 Aug 2016 06:16 pm
grab handle fogerty Interior Accessories Forum 3 14 Sep 2014 02:09 pm
Grab bar? vtmdsm27 Interior Accessories Forum 18 24 Nov 2012 08:03 pm
Grab Handles fogerty Interior Accessories Forum 3 12 Aug 2011 10:02 am
Passenger Grab Bar Removal yaschief Interior Accessories Forum 2 31 May 2008 09:16 am
