Weird Tire wear
Like Tree5Likes
  #21 (permalink)
Old 19 Apr 2017, 04:53 pm
rckstein's Avatar
Default Re: Weird Tire wear
Originally Posted by NitroPT View Post
There is no set time an alignment will last. You could even lose the alignment with a short drive and doing something so minor as parking and lightly hitting the cement stop, or even a small pot hole in the road.
But in the pictures it does appear to be parts wear among a couple of other problems that can easily be serviced to correct everything.
I usually have mine checked once a year, unless like you said hit something which could change it sooner. I just had mine checked, it had been a little over a year. There had been no change, no adjustment was needed. It had been done at the same dealership, and by the same tech because he even remembered that he had to put in the special camber bolt on the L/F the last time he did it.
'06 Touring Edition NA Automatic
151k Miles / Electric Blue Pearl
USMC '82 - '93
  #22 (permalink)
Old 19 Apr 2017, 04:57 pm
rckstein's Avatar
Originally Posted by smittey5656 View Post
It will be 6 years at the beginning of October. 70,994 miles when I first got it and about 138,700 now.
Needless to say, you were way overdue, probably something you should have had done when you first purchased it, so you have a starting reference.
Have you ever replaced the tires, before now?
USMC '82 - '93
  #23 (permalink)
Old 20 Apr 2017, 02:46 pm
I have replaced the set of 4 2x and now the pair on the front axle.
2007 Base model in Cool Vanilla 145,000+ miles
My mods: LED headlights and a K&N Intake
  #24 (permalink)
Old 20 Apr 2017, 04:19 pm
rckstein's Avatar
And how often were you rotating the tires? And were you doing the rotations or a shop?
Per the Owner's Manual, tire rotation should be done every 5,000 miles. Or you could also do it every other oil change, if you change the oil every 3,000 miles. Follow the rotation pattern in the manual.
If having a shop do it, any competent shop should have noticed the unusual tire wear and should have advised you to get an alignment. Many tire shops that have an alignment machine will also do a courtesy alignment with a new set of tires.
But stay on top of it now, and you should get much better tire wear.
USMC '82 - '93
  #25 (permalink)
Old 20 Apr 2017, 08:01 pm
Ware on the inside edge is often not noticed if not looking for it or during performing some other work. Personality I can't afford to drop $80 on a alignment if I don't see obvious issues.
  #26 (permalink)
Old 20 Apr 2017, 08:20 pm
rckstein's Avatar
Whenever I go to Goodyear, for whatever, not even tire related work, they always inspect the tires and take tread depth measurements on 3 areas across the tread, then this info in given to the customer on their invoice.
Many dealerships also do a "courtesy inspection" during the intake process, which often includes a tire inspection, because of course if they find a problem or issue, they want to sell you additional services.
USMC '82 - '93
  #27 (permalink)
Old 21 Apr 2017, 01:05 pm
I usually change my oil every 4,000 miles and rotate my tires on every other oil change (so every 8,000 miles). I have not had a problem with the tire wear until recently when the alignment was way off.
How long can 2.4 engines go before they wear out IbeCruiser General PT Cruiser Discussions 18 14 May 2016 03:09 pm
Motor mount wear? csd Tech & Performance Forum 10 24 Nov 2008 01:42 pm
Early front pad wear 06 Kzac General PT Cruiser Discussions 6 08 Jul 2006 03:34 am
Tread wear pastorj651 Wheels, Tires, Suspension 3 20 Jan 2005 05:11 pm
