Recommendation for New Struts-Want Smooth Ride
Like Tree4Likes
  • 1 Post By rckstein
  • 1 Post By _PTGT03
  • 1 Post By NitroPT
  • 1 Post By frankbiganski
Old 30 Jun 2017, 07:30 am
Default Recommendation for New Struts-Want Smooth Ride
I have 2008 Turbo Touring and I need to replace the struts. I'm going to pay a mechanic to install them, but I want to buy the struts online. The originals have over 150,000 miles on them, and they are tired, so I do want to replace the entire assembly, springs and all (rear shocks were replaced 4-5 years ago).
But the wifey has never been happy with the ride, as she says it drives like a go-cart and she wants a smoother ride.
I see there's Gabrial, Monroe, and a brand called KYB? Whatever the cost, I just want to be sure the wifey gets the smoothest ride possible.
Thanks in advance for your replies!
Old 30 Jun 2017, 07:53 am
rckstein's Avatar
Default Re: Recommendation for New Struts-Want Smooth Ride
I'm surprised you got 150k miles out of the original ones
The Monroe Quick Struts do very well for a daily driver and they're fairly inexpensive. You really could install them yourself, it only takes about 15 minutes per side and you will need an alignment after replacing. Since you're replacing the struts you might also want to replace the shocks in the rear at the same time to smooth out the ride on all 4 corners.
Handy_Cruiser likes this.
'06 Touring Edition NA Automatic
160k Miles / Electric Blue Pearl
USMC '82 - '93
Old 30 Jun 2017, 11:21 am
JonN's Avatar
I second the monroe quick struts. I replaced mine a few years ago and the PT has ridden like a dream ever since.
BIG RED '01 LE 173K
Vision Cross 16x7 Rims, 205/55/16 , Painted Calipers, Spoiler, CAI
Currently off the road
Sound System
Pioneer DEH-64BT head unit, Zapco Z400-C4SL competition amplifier, 2 10" MTX subwoofers, Rockford Fosgate P1T-S Tweets, Rockford Fosgate 6x8"s , Rockford Fosgate 6.5"'s, AudioControl 24XS crossover
Newest Car
2016 Jeep Patriot Sport 2.4L 6 speed auto 55k
Chrome grille and wheel covers
Powerstop Z23 evolution front brakes
Old 30 Jun 2017, 03:01 pm
_PTGT03's Avatar
I suggest KYB gas shocks !
Shiloe likes this.
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Old 30 Jun 2017, 03:32 pm
I just want to be sure the wife gets the smoothest ride possible.
Most aftermarket shocks and struts will not give a softer ride any model Monroe or KYB over a simple OEM stock replacement aftermarket or dealer. . I have used both and they will improve the handling sacrificing the smoothness.
The ride quality can be improved by removing the rear sway bar if equip with one and also changing the rear springs with an earlier year PT Cruiser with lots of miles and around 2004 or older. You can get these very very cheap just measure them to make sure they are both the same static height.
TIRES... can have a tremendous effect on ride quality. Shop for tires that have a high ride quality rating and reviews that users say they do feel a improved ride softness.
I currently have Noble Sport NS-20 on our PT and they are not only very affordable but having used 3 different tires makes used on our PT over the years these are by far the smoothest riding. We have used them in rain ,snow and dry weather for the last several months. In snow they will not do well if it is slush or new fallen flakes, but rain they hold very confidently. For aggressive driving on dry roads they will wash out if you push the PT to hard in turns.
BTW... it seems the number one complaint in 2001 from owners returning a questionnaire from Chrysler's PT Cruisers customers was ride quality. It may have influenced one of the reasons that the factory installed rear sway bar was removed and became a optional part.
_PTGT03 likes this.
Old 30 Jun 2017, 03:38 pm
The standard replacement OEM aftermarket shocks and struts will have a softer ride then any model Monroe or KYB. I have used both and they will improve the handling sacrificing the smoothness.
The ride quality can be improved by removing the rear sway bar if equip with one and also changing the rear springs with an earlier year PT Cruiser with lots of miles and around 2004 or older. You can get these very very cheap just measure them to make sure they are both the static height.
TIRES... can have a tremendous effect on ride quality. Shop for tires that have a high ride quality rating and reviews that users say they do fell a improved ride.
I currently have Noble Sport NS-20 on our PT and they are not only very affordable but for the having used 5 different tires makes these are by far the smoothest riding. We have used them in rain ,snow and dry weather for the last several months. The snow they will not do well if it is slush or new fallen but rain they hold very confidently. For aggressive driving on dry roads they will wash if you push the PT.
BTW... it seems the number one complaint in 2001 from owners returning a from questionnaire Chrysler to PT Cruisers customers was ride quality. It was one of the reasons that the factory installed rear sway bar was removed and became a optional part.
Old 10 Sep 2017, 07:39 am
Thanks for all of your replies. I went with the Monroe Quick Struts and had a national chain install them for $140 each (I know it can be a DYI install, but I just didn't have the time).
But right before I had the struts changed and new tires installed (Yokohamas at $140 each), I started hearing a buzzing sound when driving, and a slight (slight) vibration was felt thru the gas pedal.
I though the old tires had become worn due to the struts and that perhaps the struts were causing the noise, but the mechanic said it could need new wheel bearing & hubs, or it could be the transaxle.
I guess I'll have the bearings & hubs replaced and see if the sound goes away (hopefully that's all it is).
Thanks again for all of your replies!
Frank
NitroPT likes this.
Old 14 Oct 2017, 11:16 pm
The Monroe struts suck. I've been using them for a year. Car is lowered, they creak and make weird noises all the time.
Smooth Front bumpers CT_Cruiser Exterior Accessories Forum 4 02 Jun 2016 09:12 pm
Idle not smooth kshanok Tech & Performance Forum 63 12 Jun 2015 08:52 pm
Trying to make a nice smooth ride any ideas? I_want_boost Members PT Project 2 10 May 2015 11:03 am
after oil change, rough idle first, smooth out later edb General PT Cruiser Discussions 8 14 Feb 2011 04:40 pm
smooth roll pan airevac19 General PT Cruiser Discussions 2 01 Jun 2004 10:01 pm
