Should I Be Worried?
Like Tree6Likes
Old 09 Sep 2017, 02:55 pm
KalebSikora's Avatar
Default Should I Be Worried?
I have damage/rust on my polished alloy rims of my 2008 PT. Should I be worried about this? Some of the rust on the back passenger rim seems to have spread to the body and it looks cracked! Here's the pictures of the wheels.
Old 09 Sep 2017, 03:13 pm
_PTGT03's Avatar
Default Re: Should I Be Worried?
yes
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 9800i and Escort Shifter ZR4, front facing traffic camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Electric valve actuated Y-pipe with catalytic converter delete. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Old 09 Sep 2017, 03:21 pm
Originally Posted by _PTGT03 View Post
yes
What he said ^^
Old 09 Sep 2017, 05:10 pm
What can I do about it?
Old 09 Sep 2017, 05:41 pm
Handy_Cruiser's Avatar
Okay, that looks like salt corrosion. You might be able to help it with polish but it will never be perfect again at this point. If me, I'd start with a polishing compound made for alloy wheels and see how well it does. Once shined back up, I'd use two or more coats of synthetic wax to help protect them. Others may have some additional good ideas as well.
Old 09 Sep 2017, 07:11 pm
Carnut's Avatar
Think I'd unmount wheel from car, sand corrosion smooth, tape off tire and spray with a chrome silver paint or some other complimentary color on all 4 wheels.
George H. McDowell
Wichita, Kansas
mailto:carnut@carnut.com
http://www.carnut.com/
FB https://www.facebook.com/george.c.mcdowell
My 2005 PT Cruiser GT Convertible Project
Old 10 Sep 2017, 12:50 am
These wheels have a clear coat. Waxing will really build your arm muscle but do nothing for the problem.
It is time to shop for other wheels or locate a sand blasting company,powder coater or just a good custom body shop in your area and have them stripped and blasted and do your own custom pant and or polish.
Busted_PT and VsandFords like this.
Old 10 Sep 2017, 05:50 am
Like above, you Have a clear powder coat on them. Salt has penetrated. Now this didn't spread to the body. It to is affected by the salt. You might want back the clear in the areas affected and polish the metal to the same finish as the rest if the wheel. Then spray some clear on it to make it look closer to the rest of the wheel. At least from 10 feet or so.
Old 10 Sep 2017, 06:35 am
Using a shop to do this would likely cost more that the wheels are worth. If I couldn't polished out the corrosion myself, refinish them myself as Carnut suggested and/or just live with them best I could on an aging PT, I'd look for another set of rims. But hey, it never hurts to get some quotes.
Old 10 Sep 2017, 10:18 am
Um...you might check around your area for prices on stripping a wheel and or media blasting them. Many services of this type charge *25 per wheel for basic stripping. So 100 for the set and then 2 cans per wheel average rattle can paint and wheel clear coat about 15 bucks a wheel. So for about 160 you get a nice set of rims....
Those rims are not bad looking.....
*The stripping cost is what I charged to strip most wheels of this type to prep before powder coating. I would first apply a coat of aircraft stripper or Jasco Paint remover on the wheel let them sit for about 20-30 minutes. Rinse off with water and then a light media blasting which took about 5 minutes a wheel.
Then off to get powder coated. Depending on the color or colors chosen a set of wheel like the the ones in this thread would run about 400 clams.
Worried about auto transmission DIYPTGUY Tech & Performance Forum 23 23 Dec 2009 02:18 am
This one has me worried oldunclelar General Turbo Discussions 3 02 Nov 2008 07:21 am
Now I'm Worried! BB General Turbo Discussions 19 11 May 2008 07:28 am
Worried about purchasing PT convertible.... Sas PT Cruiser Convertible Forum 0 11 Aug 2005 02:02 pm
