Steering jerk
Old 11 Sep 2017, 08:03 pm
Default Steering jerk
2003 PT cruiser base, 125K. I recently replaced both front wheel bearings and PS hose. right wheel bearing actually failed and was broken. Issue, after making a sharp left turn coming up to speed, shifting to third gear the car makes a sudden jerk to the right. Appears to be less severe when accelerating fast. I have not noticed similar response coming out of a right turn. Car seems to drive and track well after shift coming out of left turn. Has been consistent at the moment of shifting to third gear. Suggestion?
Old 16 Oct 2017, 01:31 pm
Default Re: Steering jerk
I have an 02 with the EXACT same problem! However, I know that the front steering and suspension are in bad need of work
Lower Control Arms
Sway bar links
in the rear the bell crank
I have been told by several mechanics that it could be tie rod related or possibly even the rack itself.
I have also had it suggested that it maybe related to the bell crank not working properly.
If I ever figure it out, I will let you know...and I hope if you figure it out, you will let us know.
2007 tour edition Jerk when braking Djeantelle Tech & Performance Forum 1 04 Feb 2016 08:08 am
steering Fifty4F100 Tech & Performance Forum 7 14 Mar 2015 04:27 pm
A/C causing car to jerk.?? clark6 General PT Cruiser Discussions 18 12 Sep 2011 04:05 pm
steering ford1254 Wheels, Tires, Suspension 4 30 Jan 2009 08:17 pm
