Clunking in right front area
Old 01 Oct 2017, 07:23 pm
RVC RVC is offline
Default Clunking in right front area
I've been searching for this for a while and finally discovered there is significant play between the right tie rod and to whatever it connects to when it disappears into the rubber bellows on the steering gear.
This definitely needs to be repaired as the play is considerable. Is this a servicable item for a home mechanic? Must the steering gear be removed to enable replacement or repair of the problem in question? I have the downloaded pdf service manual and a quick glance through it hasen't revealed much so far - perhaps it will as I progress farther into it.
If there are those who could give some guidance it would be appreciated. This is my only transportation.
Thanks.
RVC
2002 2.4L Woody Normally aspirated
Purchased 2/29/16 w/ 104,048 miles
Old 01 Oct 2017, 08:38 pm
_PTGT03's Avatar
Default Re: Clunking in right front area
replace the right front control arm. its bushings have been worn out.
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Old 01 Oct 2017, 08:46 pm
RVC RVC is offline
Thank you for your response. I have replaced the right control arm. The rear bushing was in bad shap as you suggest. However it did not aleviate the problem. Further inspection revealed the slop I mentioned in the steering. That is what this post was about.
RVC
Old 01 Oct 2017, 10:34 pm
_PTGT03's Avatar
RVC
hi, you didn't even mention that in your original post, so that would have helped your cause.
there's something called an inner tie rod on the steering rack. they usually dont go bad as often as outer tie rods but it's not un heard of. that's a more likely cause here. also the factory service manual does not have procedures for servicing the steering gear inner rods. however it's straight forwards.
perhaps you just need this one part, or an entire rack, i have not done this particular job so i don't know for sure. but it's worth trying as the inner tie rods are under $20 on rockauto.
front end clunking noise Carl48 General PT Cruiser Discussions 11 28 Nov 2016 07:47 am
clunking noise front right tire area quenuss Tech & Performance Forum 3 14 Oct 2014 07:08 pm
Clunking noise in front RoseDust Tech & Performance Forum 4 19 Sep 2011 10:21 pm
Front end clunking noise discovering06 Tech & Performance Forum 1 26 Feb 2011 07:01 pm
clunking sound from front right end when turning any TSB mino General PT Cruiser Discussions 5 18 Oct 2007 03:04 pm
