Steering wheel not centered
Old 11 Oct 2017, 01:08 pm
Default Steering wheel not centered
HI,
After replacing the front left wheel bearing and the right tie rod the steering wheel is now almost at 90 degrees.
Not centered.
Is it easy to fix?
Thanks
Old 11 Oct 2017, 01:14 pm
Default Re: Steering wheel not centered
Did you replace the tie rod end yourself? If so, you should have counted the number of turns it took to remove it and then threaded the new one on the same amount of turns. If you didn't then you can loosen the tire rod, turn the steering wheel until it's straight and then put then tighten the tie rod back. You'll need to have the alignment checked at a front end shop.
Hey, hey I wanna be a rock star.
Old 11 Oct 2017, 01:20 pm
No did not change it myself. How important or urgent is it to get the alignment done?
Old 11 Oct 2017, 01:25 pm
I can't tell you how urgent it is. You have to determine that yourself. If you're driving on the highway at the posted speed limit and let go of the wheel, does the car drift to one side or the other or go straight? If it drifts, then you need to have the alignment done and you can ask them to straighten the steering wheel. If it doesn't drift, then you can either live with it the way it is or take it in for an alignment check. If it's not in alignment, then you'll start wearing out the front tires before long.
Old 11 Oct 2017, 01:35 pm
Doesn't really drift, just a bit, but the steering wheel almost vertical is annoying . But the car runs good.
If i can just figure out why when i accelarate starting 50mph it just seems like missing power and starts kicking but if i accelarate slowly it's ok.
No check engine.
Thank you for the help.
Old 11 Oct 2017, 01:39 pm
When's the last time you had or did a tune up? I'm talking plugs, wires, air filter and PCV valve. And you might want to try a bottle of Techron Fuel Injector Cleaner in a tank of gas. You may have an injector getting dirty or clogged. And a good throttle body cleaning won't hurt it any either. Just be sure to use throttle body cleaner and NOT carburetor cleaner or brake cleaner. They'll strip the coating out of the throttle body that needs to be there.
Old 11 Oct 2017, 02:01 pm
rob302's Avatar
That's annoying with how the turn signals cancel as well
That's a really crappy repair job. Did a shop do it?
Old 11 Oct 2017, 02:49 pm
rob302's Avatar
i have very harsh chemicals at work and NONE of them take any coating off the throttle body. i used brake cleaner on mine as it's my go-to cleaner. i also tried lacquer thinner, toluene, and MEK just to see. the TB busted sent me is destined to be installed on my exhaust like a dump so chemicals ruining the finish is not an issue. none removed anything but dirt/grease/grime. it's the caustically high/low PH aluminum pitting cleaners that must be avoided. oven cleaner, purple power, zep, etc. TB cleaning is for idle or sticking throttle issues though, so i'd say they can skip this
aftermarket tie rod ends differ in length so this is not true unless the new and old are identical, which has never happened to be the case in my experience. on my PT the one i replaced was over 1/8" different in length. instead i measured center of tread front and back of the wheels with a tape measure. after that i lowered the car off the lift, bounced on it a few times, rolled it back and forth, and then measured, adjusted, and repeated the process. once they were equal, i tightened the jam nut. it was close enough that i never took it for an alignment because it felt perfect driving.
not trying to be arguementative, just disspelling a couple myths i commonly run into
Old 11 Oct 2017, 02:58 pm
rob302's Avatar
who ever fixes it, make sure they actually adjust the tie rods. they could also cut corners by taking the steering wheel off and just sticking it back on straight.
Old 11 Oct 2017, 03:16 pm
All ty rods are not equal length, to get them close I clamp a pair of vice grips on to the inner shaft and measure to the center of the grease fitting before removing the old one. I can adjust the length after installing the new one to match the original measurement.
Get you front end aligned immediately or you have either toe in or toe out which in either case will ruin (remove) the edge of the tires.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
How to center/make sure your clockspring is centered? Dude13450 General PT Cruiser Discussions 0 22 Sep 2015 08:42 pm
New steering wheel Ray_Dockrey Interior Accessories Forum 10 24 Jul 2013 10:16 am
wheel skin steering wheel cover chintzgirl Interior Accessories Forum 0 23 Oct 2010 08:05 pm
Steering wheel RecruitPt Interior Accessories Forum 8 19 Jun 2010 12:14 am
Steering Wheel mljorg Classifieds: For Sale/Trade 0 30 Jan 2009 06:36 pm
