Bell Crank Question
Like Tree4Likes
  • 3 Post By rcktpwrd
  • 1 Post By Birdman
Old 17 Oct 2017, 01:52 pm
Default Bell Crank Question
Is it possible to undo the lateral links at the body, unbolt the bell crank from the axle and take it all out as one piece? Or do I have to remove the ball joint end from the bell crank to remove it all?
I'm looking at replacing all of it, so if I can take it all in one part and the put the new stuff in as all one piece, it would save me a pile of extra work.
Old 17 Oct 2017, 02:47 pm
rcktpwrd's Avatar
Cool Re: Bell Crank Question
Yes you can somewhat easily unbolt the end-links from the car. The ends of the lateral links have bushings with a through bolt. Then unbolt the bell-crank from the axle and pull the whole thing out. The ball joint ends aren't meant to be removed from the lateral links, the tubing is crimped down on the threads.
When I replaced the watts linkage in mine, I removed it all as one unit and installed the new one as one unit.
Joel
2001 PT Cruiser 5-speed; 1976 Oldsmobile Cutlass S; 1990 Chevy 454SS; 1989 Chevy Suburban 2500
www.rcktpwrd.com
Old 17 Oct 2017, 04:07 pm
Default Re: Bell Crank Question
Thank you... I think that will save me a HUGE amount of work!
rcktpwrd likes this.
Lateral Link end going into the Bell Crank sscanlan Wheels, Tires, Suspension 34 22 Jun 2015 11:57 am
Watts Link Bell Crank Jassy Tech & Performance Forum 2 16 May 2013 03:55 pm
Help with bell crank replacement needed stratman Wheels, Tires, Suspension 3 22 Sep 2009 11:14 pm
Bell crank bf4cm28 Wheels, Tires, Suspension 3 22 Mar 2009 05:07 pm
Bell crank Back order steelheep General PT Cruiser Discussions 0 02 Dec 2008 09:58 pm
