PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   Wheels, Tires, Suspension (http://www.ptcruiserlinks.com/forum/wheels-tires-suspension/)
-   -   Wheel size and ride height changes: effects on ride and handling? (http://www.ptcruiserlinks.com/forum/wheels-tires-suspension/64938-wheel-size-ride-height-changes-effects-ride-handling.html)
niggle 21 Oct 2017 06:20 am
Need to change the stock 16" wheels on our 2002 Street Cruiser 2.0l petrol due to severe chrome plating corrosion, but what would be the impact on ride and handling of going up to 17"? Car rides well on 16s but handling could be a tiny bit tighter IMO. Alternatively what about the effect of reducing ride height 30mm with some decent lowered springs and keeping to 16" (and the current tyres which have very little wear)? Or what about doing both? :devil:
Sinbad 21 Oct 2017 06:48 am
Re: Wheel size and ride height changes: effects on ride and handling?
Each to their own, but my 2 pennorth would always get more tire than wheel.
These cars are harsh enough anyway, IMHO - and handling is never going to be amazing unless you throw zillions at it, and even then - it's still a glorified van :D ... plus, big tyres suit the Old Timer look (again, IMHO)
For which reasons I run oversize tyres - currently 195/65 15 on steelies.
Comfort... and it still hangs on OK on bends.
Most VW wheels will fit a Cruiser by the way - check this, but I think it's up to Golf V and the same dateline of Audis. After that, VW changed PCD on the wheel nuts.
niggle 22 Oct 2017 03:18 am
Thanks, I am leaning towards sticking with OEM 16" and getting some use out of the current tyres. Mildly lower springs may come in the future if SWMBO permits, but not if this would be at the expense of ride comfort. In our part of the world if the road is not bending to the left, then it is bending to the right, but OTOH the surfaces vary from patchwork quilt to lunar.
NitroPT 22 Oct 2017 10:50 am
There is occasionally LOW TECH lowering spring set for sale on ebay. They are progressive and the rating is actually slightly softer ride up to about an 3/4 inch compression over a stock spring.
Remember size when thinking about tire sizing on a PT Cruiser, taller sidewall is not a freind to these front heavy vehicles and you will sacrifice some emergency steering and handling control.
niggle 23 Oct 2017 04:46 am
Cannot find Low Tech springs for sale in the UK, but Eibach Pro Kit are readily available and affordable- best price for a set is 116 with free postage. These are also progressive rate and 30mm lower all round, and a well known brand.
Sinbad 23 Oct 2017 05:58 am
I know someone over here runs the -30mm Eibachs and he has no complaints...
Sinbad 23 Oct 2017 06:08 am
Upsizing tyrewall height a tad will not make a shred of difference to handling or braking, but will make a LOT of difference to how compliant the ride is - plus it will give you a tad better miles per revs and better cruising economy.
If you want to screw up the handling, get wheels with the wrong ET and see what happens...
No way would I advise putting more than sensible on the wall height, and even then with the usual caveats that YMMV and do at your own risk - I am just saying what works for me.
Here is a handy calc that can help :) https://www.wheel-size.com/calc/
niggle 23 Oct 2017 06:25 am
One way of making sure wheel choice is OK is to check it gets German TuV approval for fitting on the PT. Wheels that have this certification seem to be 6.5J, ET38 and a load rating of 610Kg or more, though the latter is probably for the worst case scenario of five 6'6" Germans plus a boot stuffed with crates of Pilsner ;), but it is reassuring when wheels are considered safe by the world's most anally retentive nation :D
Edit: check this TuV approval doc for the ITWheels Emma: https://felgen.jfnet.de/pdf/00256702/00256702.pdf
https://cdn.jfnet.de/cars360/7693-60...c-t-ffffff.png
Sinbad 23 Oct 2017 06:56 am
Not disagreeing with you, but the ol' TuV is a barsteward - you are stuck with what wheels and tyres are on your "Zulassungsbesheinigung" - how it came from the showroom originally - unless, you can find a PT that was fitted with them at the factory, prove it, and get the TuV chappy to change it for you - which they will if they know and love you, but mostly not.
What most people do over here is put the wheels and tyres you want on and notify the Versicherung (insurance) and hope they don't say "Nein! Verboten!" (they don't unless you are being ridiculous) and keep a set of bog stock wheels (usually your winter wheels & tyres) for when you get the TuV done.
In the UK, I never had any problems getting wheels through the MOT - from carlos fandango steel bandies back in the dim distant past or add on alloys, they never seemed to give a monkeys so long as they were inside the bodywork and had treads on the tyres :rolleyes:
Point being, just because a wheel has TuV does not automatically mean it is "right" or will fit - or that the ET will be right and not chuck the suspension geometry down the $hitter - ONLY if it has TuV and it is for that model car, that year, that spec, that engine...
That said, I've run both Golf and Audi steel wheels on mine and had not problems, and since they are 15" wheels and 15" is what's on my zullasung for winter use, I doubt my friendly TuV would give them a second look.
If I had a prang and the ET's were different, the insurance might if handling looked to be an issue in the accident.
That calc I posted up there will serve you well ;)
NitroPT 23 Oct 2017 08:53 am
I own a few sets of performance springs for a PT Cruiser...also a few sets of different tire and wheel combinations...
Eibach will increase the firmness of your ride
You play with words like another member on this forum but the results is still the same on a PT Cruiser and can be measured with any device that has a accelerometer, .i.e. D-Pic. ;)
Not going to argue or debate "wrong" anymore it only get people pissed as one says you can read and believe who and what you want!:)
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241
