PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   Wheels, Tires, Suspension (http://www.ptcruiserlinks.com/forum/wheels-tires-suspension/)
-   -   R&R broken front wheel stud (http://www.ptcruiserlinks.com/forum/wheels-tires-suspension/65045-r-r-broken-front-wheel-stud.html)
RVC 03 Nov 2017 08:46 pm
Can this be done in the driveway or are special tools required? My wheels are 17" mags and I need to replace one broken stud.
Thanks.
RVC
Handy_Cruiser 03 Nov 2017 08:51 pm
Re: R&R broken front wheel stud
You can do it in the drive way. Remove the wheel and the brake rotor, then use a sharp pointed punch with a hammer to knock it out the back. Put the new one in but don't try to hammer it in place. Instead, it will normally pull into place easily when tightening the lug nut. However, if it doesn't, don't over-tighten the lug nut. That may bust the wheel. Always use a torque wrench when tightening lugs on mag wheels.
rob302 03 Nov 2017 09:11 pm
Look at the knuckle before you start pounding. IIRC there is a cut out where the stud will fit out... Meaning you may need to look at the back while using common sense to see that there is room for the stud to slide out. If you skip this step you may end up with the stud wedged between the hub and the knuckle. So look, think, and rotate the hub so you have clearance behind before you start pounding:)
I would change all 5 if it were my car. They're cheap and easy
RVC 04 Nov 2017 09:53 am
Thanks, guys. I'll give it a shot and see what happens.
RVC
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
