Vibration/Shimmy at higher speeds?
Like Tree6Likes
  #11 (permalink)
Old 14 Nov 2017, 10:20 pm
Default Re: Vibration/Shimmy at higher speeds?
Originally Posted by rob302 View Post
ironically, the only two ASE certified technicians on the forum are busy arguing about chrome plated toy car plastic hood decoration in the hotwheels thread right now.
Of course the moderator has deleted the posts so I hope every got to see the show.
  #12 (permalink)
Old 14 Nov 2017, 10:40 pm
rckstein's Avatar
Got to keep something exciting, as one of them said recently that the forum activity goes up when a thread gets heated
'06 Touring Edition NA Automatic
151k Miles / Electric Blue Pearl
USMC '82 - '93
  #13 (permalink)
Old 15 Nov 2017, 01:08 am
rob302's Avatar
Talking Re: Vibration/Shimmy at higher speeds?
....dp
  #14 (permalink)
Old 15 Nov 2017, 01:09 am
rob302's Avatar
Do you have a magnetic base dial indicator to check the axles for run out? I just hate buying parts. It does make sense though because you said the axle nuts were loose when you got the car. Could be something easier like a rotor too. Just hate to see you do axles and have it persist
  #15 (permalink)
Old 15 Nov 2017, 07:23 am
rckstein's Avatar
You might also have the shop check just the rims for out of round. A couple of years ago I bought some standard steel replacement rims and after putting them on my PT it had a terrible vibration. Finally after several attempts of rebalancing and moving the tires around, Goodyear removed the tires from the rims and checked just the rims. 3 of the 4 were out round and had some "hop" to them while spinning them on the balance machine, you could see it, it was that bad. I returned them for a full refund to where I got them from as they were junk, even though they are sold as "reconditioned" which basically just means "repainted"
USMC '82 - '93
  #16 (permalink)
Old 15 Nov 2017, 08:57 pm
Thanks again for ideas. I can borrow a dial indicator to check them for runout. I guess I would need to remove the rotors and place car in neutral and then spin the hub and check it for eveness with the dial?
The wheels are the factory aluminum dream cruiser wheels. 17" aluminum. I guess that is possible, but would require complete tire removal to check like you said
  #17 (permalink)
Old 21 Nov 2017, 07:48 am
Have you checked rear wheel bearings and bushes? My old Kia Rio behaved very similarly, tyre balancing and wheel alignment did nothing then at MOT it failed on a rear bearing and when that was replaced it was cured (well for six months until the other one went )
  #18 (permalink)
Old 22 Nov 2017, 08:04 pm
Yeah the rear wheel bearings are tight with no slop so they appear good. When I get time I am going to try and swap my spare tire in at each spot to see if I have a bent wheel or something like that
  #19 (permalink)
Old 17 Jan 2018, 01:27 pm
Any update on this issue?
Higher idle RVC Tech & Performance Forum 1 21 Oct 2017 12:19 pm
Rough Feeling Around 40mph, Pedal Vibration/Wheel Vibration Flash619 General PT Cruiser Discussions 6 12 Aug 2017 02:14 pm
Heavy front end vibration at high speeds Patrick_Dickey Wheels, Tires, Suspension 5 07 Jul 2015 10:00 pm
higher price = higher quality? edb General PT Cruiser Discussions 13 26 Oct 2011 05:05 pm
