rear tire bouncing
Like Tree6Likes
  • 1 Post By RickinPA
  • 1 Post By rcktpwrd
  • 2 Post By LionPT
  • 1 Post By NitroPT
  • 1 Post By rsrocket1
Old 06 Dec 2017, 06:20 pm
markeele's Avatar
Default rear tire bouncing
When i got to work today a buddy told me my passenger side wheel appeared to be bouncing i did notice a bit of vibration but it wasnt awful.anyway i checked the tires and all appears to be good so what could cause the bounce, anyone else experience this and if so what was the fix
Old 06 Dec 2017, 07:25 pm
RickinPA's Avatar
Default Re: rear tire bouncing
Sounds like a bad shock absorber to me. Replacing rear shocks on the PT is an easy job.
ptprice likes this.
Old 06 Dec 2017, 07:28 pm
rcktpwrd's Avatar
like posted above sounds like a bad shock, possibly also a tire slightly out of balance as well...
ptprice likes this.
Joel
2001 PT Cruiser 5-speed; 1976 Oldsmobile Cutlass S; 1990 Chevy 454SS; 1989 Chevy Suburban 2500
www.rcktpwrd.com
Old 06 Dec 2017, 08:02 pm
LionPT's Avatar
A broken belt in the tire or a bent rim would also cause this problem.
ptprice and Carnut like this.
Nexus 5X, Nexus 4, Nexus 7 (2013)
Old 06 Dec 2017, 08:04 pm
ptprice's Avatar
It could be low tire pressure, loose lug nuts, bubble on tire, as mentioned tire out of balance, bad shocks, bent rim and as a last resort replace jounce pads on the rear end. The photo give you a peek how it looks under there. Good luck.
Happy Ptin', ptprice
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Custom Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. Aluminum Chrome Clad 16" X 6" Wheels, P250/55 R16 Cooper Touring tires, Touring Suspension. Chrome Package; Side Spears, Grills, Fuel Filler Door, Door Locks, Handles, PRND3-1 Bezel, Silver/Chrome Shift Ball/Knob, Bright Spoke Leather Tilt Steering Wheel. Chrome Tail Lights, 3/8" Belt Trim. Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry, Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Under Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers, Back up Camera/ 7" Monitor.
Old 07 Dec 2017, 11:43 am
rob302's Avatar
i vote leaky shock if the wheel only bounces over bumps. ...because i've been meaning to change the right rear shock on the minivan for a year now. the shock juice leaked out and now the tire bounces when i hit a bump.
Old 07 Dec 2017, 11:50 am
Jack-up the suspected corner place a jack stand for safety under the appropriate area to support the PT cruiser. Than rotate the tire/wheel and see what you can find. If there is nothing there then carefully inspect all the suspension components for damage or wear. If you do not see anything than I would recomend that you take your PT cruiser to a service shop for a brake and suspension inspection.
ptprice likes this.
Old 07 Dec 2017, 01:00 pm
When I had this problem I did the jack up and rotate tire routine and found a bubble in one of my tires. I tried to do the visual inspection first but didn't find anything wrong. I am finding that with the tires lasting a long time with checking the air pressure routinely that they sometimes go bad in other ways (bubbles, rotting, nails, out of balance, etc.).
How many miles do you have on the tires?
Old 08 Dec 2017, 11:16 pm
Shocks. All other causes here will be a constant. Had this happened on one of mine. It'll get worse. Bounce like a basketball.
Old 09 Dec 2017, 09:52 am
rsrocket1's Avatar
A simple test would be to push down on the corner of the car. If it bounces more than once, the shocks are certainly toast. Leaking shocks are also a good reason to replace them. The first repair I did on my PT was to replace the rear shocks. It took about 15 minutes for each side. When I removed them, the old one were leaking and had no bounce back. I showed my son how easy it was and he helped with the other side. I thought, small car, probably gets good mileage, easy to replace parts, good purchase!
Little did I know the slippery slope I was about to travel when I started performing repairs and maintenance on the PT
Busted_PT likes this.
Front end bouncing unknowndeath497 Wheels, Tires, Suspension 10 22 Dec 2016 06:14 am
rear tire chopping?? mdskinner731 General PT Cruiser Discussions 11 21 Jul 2012 07:44 am
rough chugging bouncing under 1000 RPM wednesday Tech & Performance Forum 4 17 Dec 2011 02:42 pm
rear tire sizes Ed Lim Wheels, Tires, Suspension 4 06 Jun 2003 08:12 pm
Rear tire sizes Ed Lim Wheels, Tires, Suspension 0 31 May 2003 01:23 am
