Adjustment after passenger side control replacement?
Old 25 Dec 2017, 07:25 pm
Default Adjustment after passenger side control replacement?
I just got done replacing the passenger side control arm. According to the manual the engine is supposed to be adjusted so the difference between the reference points is 119 mm. I measured before rotating the engine and it was 119 mm. Does that mean the adjustment is complete without doing anything? Thanks
Old 25 Dec 2017, 09:44 pm
Default Re: Adjustment after passenger side control replacement?
Double checking after running it won't hurt anything.
Old 25 Dec 2017, 10:01 pm
oldthom's Avatar
Mine was the same after putting new dog bones on after a belt replacement. It was right on 119 mm.
2004 LE "Dolly" 61K miles
Old 26 Dec 2017, 11:36 am
Handy_Cruiser's Avatar
Yep. As long as you don't loosen both top and bottom strut mounts at the same time, there doesn't seem to be much chance for movement if the one staying in place is in good condition. But you should always check to make sure after changing out one of the two mounts.
Old 26 Dec 2017, 06:07 pm
Thanks for the input. I guess I'll call it good unless something changes.
Old 07 Feb 2018, 10:08 am
You're supposed to loosen both upper and lower motor mounts. The distance at the top will be the same because you didn't loosen the bolts but the rubber bushings won't be loaded correctly.
2008 PT Cruiser Touring 123,000 miles
Can side airbags be swapped into replacement front seats w/o side air bags? ptprice General PT Cruiser Discussions 2 05 May 2017 05:40 pm
Changing a passenger side mirror: replacement or no? matthewsf General PT Cruiser Discussions 3 14 Feb 2017 05:07 pm
Filled torque struts on the Passenger side, what options are there for Trans side?! SPLNeon Tech & Performance Forum 7 09 Dec 2014 04:06 pm
Passenger side strut replacement, any complications? Kell Tech & Performance Forum 0 02 Feb 2010 02:46 am
Passenger Side Oil Leak rleey07 PT Cruiser Convertible Forum 3 18 Jan 2010 09:54 pm
