Spare Tire Retaining Bolt/Hook Alternative
Like Tree3Likes
  • 3 Post By waxclan
Old 30 Jul 2018, 09:04 am
Default Spare Tire Retaining Bolt/Hook Alternative
Was reading the forum last night and noted we should check the spare to make sure it is servicable. This morning I went to lower mine and the hook broke off. After seeing the replacement cost, I substituted a 6" x 3/8" turnbuckle for the whole mechanism.
To retain the same 19 mm fitting for lowering the spare I took the bolt head end (top end) of the broken hook/bolt and cut it flush with the convex side. There is a pin you knock out from the underside that makes the interference fit of the assembly, then drilled the remaining piece out enough to knock it out leaving a small hex-head hole. With the turnbuckle, I got rid of the right hand eye-bolt and replaced it with a standard 3/8" bolt or piece of all thread and nut. I ground the 3/8" bolt head (or nut) down to become a new interference fit in the existing convex fitting. A standard nut pulled the interference fit head/nut into place and secured the assembly.
I still need to get a left hand thread 3/8" nut to secure that end of the turnbuckle to stop the turnbuckle body from turning but the new assembly fits well and works.
Old 11 Aug 2018, 11:32 pm
Default Re: Spare Tire Retaining Bolt/Hook Alternative
I did something similar to what you did shortly after I got my Cruiser and my hook was rusted together and broke. I used the improvised one for a few months before I decided to get a new one from the local Chrysler dealer. I think it was about $35.00
2002 Limited Edition 2.4 Auto with 177k Miles
ISO Spare Tire Hanger Bolt supersour Classifieds: Want To Buy 11 27 Oct 2014 10:05 pm
Need the bolt/hook for the spare tire rack. parkerc Classifieds: Want To Buy 7 09 Sep 2013 09:02 pm
Bolt/hook for the spare tire rack - what fits a 2001? checkit Wheels, Tires, Suspension 3 05 Jul 2013 07:30 pm
WTB - Spare tire bolt Hannah Classifieds: Want To Buy 4 16 Jan 2011 02:57 pm
wtb bolt for spare tire carrier ReverantFire Classifieds: Want To Buy 0 05 Nov 2010 11:26 pm
