Sqeak and thud noise
Like Tree2Likes
Old 14 May 2019, 09:15 am
shelbyzman's Avatar
Default Sqeak and thud noise
My PT makes a squeaky noise and thud when hitting bumps. Sounds like from the front passenger side. The squeak is worst when it is cold (over 70 degrees, I don't even hear the squeak). After driving for a while the squeak goes away completely. I have had the motor mount/strut mounts changed except the bottom one (seems to be in ok condition). Any ideas? The struts seems to be good (don't have excessive bounce or anything when hitting bumps). Any ideas?
2007 PT Cruiser GT • 5-speed • 17x8 Konig Inception wheels • K&N style intake • auto throttle body • Spec D tail lights • Blow off plate • 10.2mm plug wires • Cat-Back "DNA Motoring" exhaust w/ Thrush glasspack • "blacked out" • DIY ground effects
Old 14 May 2019, 10:37 am
Handy_Cruiser's Avatar
Default Re: Sqeak and thud noise
There's a 90% chance it's the rear bushing on the front lower control arm. Moog makes a redesigned control arm bushing so it doesn't happen again. You will need a shop press to remove the bushings or you can buy complete control arms.
Old 14 May 2019, 02:05 pm
A badly worn ball joint will also make the thump as it slips back into its holder, IF IT DOESN'T- and comes all the way out you will loose control as it will flip the wheel to the side forcing you off the road, hopefully not into someone else.
It happen to me, lucky I was only going 20 MPH on back road, noone around.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 14 May 2019, 02:35 pm
shelbyzman's Avatar
Is there a surefire way to check it to make sure it is the control arm that is shot? There is 0% vibration or play in the steering wheel.
Old 14 May 2019, 03:14 pm
shelbyzman's Avatar
Did you have any other issues before this happened? Loose steering etc.? My steering wheel doesn't vibrate and there is no play.
Old 15 May 2019, 09:58 am
This doesn't really seem to affect alignment too much. You just get the ubiquitous bump with you go over things. Sometimes you can feel it right under you feet because it kind of is.
To check for this, look at the bushings and see if the rubber is torn and if the top of the part of the control arm around the bushing appears to have been able to hit the chassis.
And here's my write up on all of this:
The "Handy" Control Arm Replacement
rockandroller likes this.
Old 15 May 2019, 10:47 am
shelbyzman's Avatar
Thanks for the pics/write up! I appreciate it
Handy_Cruiser likes this.
Old 27 May 2019, 09:48 am
shelbyzman's Avatar
I changed the lower strut (motor) mount and noticed that the control arm bushing does look pretty bad. Money is tight and don't have multiple cars....will it hurt anything to leave it as is? The steering it good, no play or vibration. Is it a safety issue at this point?
Old 27 May 2019, 12:08 pm
Ya..... go to a Firestone and have them do a free suspension and brake inspection.
You would not necessarily get vibration or play in the steering wheel... but really because you have power steering unless you have the proper measure tool to measure for steering wear or get the PT off the ground in the front and with an assistant perform some test it is next to impossible to say if you have 0% steering play.
Old 27 May 2019, 12:14 pm
What state do you reside or where do you live...curious?
Any suspension part worn or damaged left unattended will advance the wear on other suspension parts.
No one can answer the SAFETY question by simply looking at pictures posted on the internet. This is again a recommendation to have your PT Cruiser checked out be a shop!!
Belt sqeak PTloser32805 Tech & Performance Forum 11 25 Feb 2018 04:35 am
"Thud" Noise and Temperature VroomMaster Tech & Performance Forum 3 09 Sep 2011 09:04 pm
Slight vibration in steering, squeaking noise coming from wheels, thud when braking thinkinboutit General PT Cruiser Discussions 6 10 Oct 2010 11:31 pm
2005 PT with thud/ vibrating from wheels muzzle17 Wheels, Tires, Suspension 6 04 Jan 2010 07:53 pm
Engine idle sound and thud/pop when powering off KingKole02 Sound and Security Forum 10 04 Jul 2009 09:34 am
