Lower Control Arms
Like Tree12Likes
  • 1 Post By rambojoe
  • 1 Post By rsrocket1
  • 1 Post By RCSnyder
  • 7 Post By circus
  • 2 Post By circus
Old 04 Jun 2019, 05:03 pm
Macgyverman1123's Avatar
Default Lower Control Arms
Hey guys!!
I'm looking to replace my front control arms soon, they really need it!
It looks relatively straight forward and I'm sure I can do it, since this isn't my first time to the ball, but at every online guide and video I see, there's always some Neanderthal cutting a giant hole in the floor to get out the vertical stud. This seems absolutely ridiculous to me, is there any way to get around it? From what I understand, this is done when the vertical caged nut either breaks off in the frame or is stripped. Could this potentially be avoided by hitting it with some penetrating fluid or maybe heating it with a torch to ease the removal?
:Beer:
-John P.
Go Canes! #TakeWarning
Old 04 Jun 2019, 06:32 pm
rcktpwrd's Avatar
Cool Re: Lower Control Arms
RockAuto has a MOOG kit at a good price:
MOOG control arms
Joel
www.rcktpwrd.com
Old 04 Jun 2019, 08:06 pm
Default Re: Lower Control Arms
I live in the rust belt of Western Pennsylvania, when I changed the LCAs on my 2001 the left side captured nut which is the rear vertical bolt spun in the frame and the only way to get to it was cutting a hole in the floor under the brake pedal. I could not budge the bolt from below until it spun the nut.
Being that you a bit south you might not have a problem. To heat the nut you would have to pull the carpet back and cut the hole. I drilled a small hole above where the bolt goes through LCA into the frame and tried lubricant to no avail. Ended up having to cut with a sawzall the bolt to remove it. Right side came out without much struggling
Good luck on this adventure.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 05 Jun 2019, 07:25 am
even in Arizona (re-no rust) 9 times out of ten when we swap any components underneath big rigs or equipment- shocks springs axles ect- I don't even bother trying. bolts and nuts get cut preferably with a angle grinder...
of course we have a wall of every nut and bolt in every size ever made...but trust me- Chrysler has a pile of this crap at your dealer...
but ive never done the arms on the pt so I have no clue- just telling you how I approach things. some bolts I deal with are tourqed to 500+ ft-lbs!= cut it...
edit- remember your dealer is more than happy to deliver to your house. a lot of people forget this... that kid in the delivery truck is just picking his nose!
_PTGT03 likes this.
Old 05 Jun 2019, 09:41 am
I didn't have a problem replacing mine. The most difficult is getting the proper torque on the long bolts when you reassemble it. IIRC the torque is supposed to be 180 ft.lb. My torque wrench only goes to 150. I'd suggest you just heat them up, get the socket on there along with a cheater bar and try to tighten it just a little bit first, then try removing them. Mine came out with some effort, but I don't have any impact tools. If you're using an impact, I'd highly recommend trying to break them loose with hand tools first just in case they're rusty.
Old 05 Jun 2019, 12:14 pm
If you try heating from below the heat will catch the bushing on fire because the nut is about two inches above the head of the bolt head. when I cut the floor open, there is an indentation where the nut is located, I just cut a three sided hole with air chisel , if you need to.. Heat the nut not the bolt.
I just removed two exhaust flange bolts that have been on since 2006 by heating the nut cherry red much to my suprise.
73 Charger SE
01 Sebring flip
Old 10 Jun 2019, 08:23 pm
rsrocket1's Avatar
Mine came off in a cloud of red dust and no spinning of the captured nut <whew> even though I bought a grinder/cutter just in case.
I used my Milwaukee corded impact wrench to loosen the bolt. I think a sudden blast of an impact wrench is better than a slowly increasing torque of a breaker bar. That slow torque can cause the buried nut to break loose from the housing. Unfortunately there is no way to seep penetrating oil from the bottom of the LCA. It can only come from the top and you have to cut through the floor to get to it.
Even though this PT lived most of it's life in San Diego and probably never saw road salts, the bolt had a lot of rust on it and was solidly fused into the body. However, when I pulled the splash shields off the fender, I found a lot of wet sand that probably kept the rust growing over the years.
Good luck on your job.
rockandroller likes this.
Old 17 Jun 2019, 05:24 pm
Heat and patience are good advice...
I've done a-arms on every PT that has passed through my garage and only had one spin the nuts, requiring a Plan B.
I had one I was concerned would spin a nut, so I took a preemptive move.
Both cases had me lifting the carpeting, locating the "patch" panel and making a hole. The first has me cutting out most of the panel out while the latter was just a small hole punched through for the penetrating oil nozzle.
I guess I'm suggesting lube and heat it if you are so inclined from underneath, AND if you think you're pulling harder than you should, go topside and poke a hole a before you spin a nut.
My 2 cents.
Bob in Liberty, MO
Old 21 Jan 2020, 06:12 pm
Rust capital Wisconsin. Thank you, thank you, thank you, for the heads up about the control arms vertical bolt. I preemptively drilled a 1" hole in the floor and took a peek. Egads. Rust made the bolt 50% bigger around, couldn't even make out any threads and it had about 3 inches of that nightmare to turn out in order to remove.
I stuck a sandblaster nozzle in the 1" hole and let her rip for a couple seconds. Oiled it, turned it 180 then blasted the other side of the bolt. Bolt came out like a dream making assembly a lot easier. Think I'll caulk a quarter over the hole when I'm done. Dodged another bullet.
Old 23 Jan 2020, 08:51 pm
I'm surprised the bushings improved the ride so much. The rubber was only unattached from the sleeve in the old ones. I didn't hold much hope but boy was I wrong. For future reference bad control arm bushings can be misconstrued as something unbalanced.
rcktpwrd and chuzz like this.
Lower Control Arms chuzz General PT Cruiser Discussions 11 23 Mar 2016 09:12 am
Lower control arms So much fun Flintster1436 Wheels, Tires, Suspension 1 12 May 2013 11:01 pm
Help -- Lower control arms caretta General PT Cruiser Discussions 0 24 Dec 2009 04:03 pm
lower control arms. AlexJB Classifieds: For Sale/Trade 2 01 Dec 2008 05:25 pm
Lower Control Arms delrosen Tech & Performance Forum 3 10 May 2008 04:43 pm
