Wheels Spacers and Front End Vibration
Like Tree19Likes
  #31 (permalink)
Old 01 Apr 2020, 09:34 am
soonercruiser's Avatar
Default Re: Wheels Spacers and Front End Vibration
Originally Posted by Sinbad View Post
Which anti-seize do they recommend for wheel nuts?
I usually only find one brand hanging at the auto stores.
Not sure what brand it is.
Frank, aka SOONERCRUISER,
  #32 (permalink)
Old 01 Apr 2020, 09:38 am
My Subaru racing son this morning recommended...
THAT IF YOU WERE GOING TO USE WHEEL SPACERS....
Just have longer studs installed on the hub, rather than two sets of nuts!
Personally, I found TWO NUTS very useful!
  #33 (permalink)
Old 01 Apr 2020, 10:53 am
If you do this you need to more frequently check your nuts.....
Seriously it is a good idea but most wheel spacers are aluminum and during tracking a car the wheel even steel will flex (very small degree's nothing drastic) as well the aluminum spacers and the lug nuts on a studded assembly will start to become lose.
I run longer studs and wheel spacers on one of my MINI's and after a few laps at Leguna Seca I need to re-torque them.
As for anti-size on lug bolts or studs I am always very cautious of applying it because of the chance getting anti seize on the rotor or pads.
I prefer more often to carefully apply and use GIBBS.
soonercruiser likes this.
  #34 (permalink)
Old 01 Apr 2020, 04:04 pm
Do you have to use a mini torque wrench on Mini????
NitroPT likes this.
  #35 (permalink)
Old 01 Apr 2020, 05:05 pm
Very funny Frank......
  #36 (permalink)
Old 09 Apr 2020, 12:47 pm
MYSTERY SOLVED!!!!
Before the final resolution, I got another front end alignment, and front wheels balanced.
*Because I pulled away from the house, unknowingly with the driver's side front tire down about a month ago, and I drove back to the driveway...I had them pull the driver's front tire off and be sure I had not damaged the sidewall. (Yes, I have done that before, driving too far.)
Usually there would be rubber crumbs laying in a pile inside.
NO DAMAGE SEEN!
So, this morning I drove 40 miles to my TRUSTED fav dealer...going no faster than 55 mph.
I had written the tech out a sheet of what I had done, attached to the Wilwood instructions and diagrams, and an explanation why I had to use wheel spacers.
BOOM! No longer than 15 minutes and test driving, he comes and wants to show me something!
**Although I had the right idea by going from half inch spacers to a whole 1 inch....the tips of the OEM hub lugs were still hitting the back of my Am. Racing wheels.
It did not feel like it when I mounted the wheels.
**But, the tell tale sign was that I had driven enough on them now, that the lugs made an indention on the back of the alu-min-ium wheels.
Here is a picture!
Sooooo....Yes, I could easily mount the wheels and torque them down; but, it all depended on which lugs I torqued down first as to the flushness of the mounting.
This would also explain why, when every time I took off and remounted the wheels, the wiggle through the steering wheel at 60 mph felt different....better or worst!
NOW REALIZE, that although I did match up these American Racing Torque Thrust wheels based on specs like lug pattern, offset, etc. ......they were a VW match. Which means that the VW lug pattern probably closely matches the locations of the cut-outs on the back of the wheel. (But not Chrysler)
You might ask....why not just grind the cut-outs on the back of the wheels??? (Would have to rebalance the wheels)
I asked for the best, easiest fix, and he said cut/grind off the OEM lug nuts a little.....rather than using even wider spacers.
When done, he noted that for some reason the rears only needed a little rounding on the edges....
While the fronts required a short cut, plus rounding.
Drives perfect now at 70 mph+!
NitroPT and ptprice like this.
  #37 (permalink)
Old 09 Apr 2020, 03:39 pm
Wow! this thread as fun!
hey Frank good fricken thing you didn't use thread locker (locktite)on any of the wheel studs....can you imagine..ROLMAO!?
  #38 (permalink)
Old 09 Apr 2020, 04:20 pm
This ole guy that worked on my PT has been there I started going there back in 1997....when I bought my Dodge Caravan.
He's just a lifetime of knowledge, and even the one that figured out that it was the transmitter for my door poppers that was draining my battery!
I'm sure he even has a fix for locktite lugs!
I saw a nice size sledge hammer sitting there!
NitroPT likes this.
Bought some nice wheels, now I need spacers... Wheel Spacer question comin' atcha bricks4584 Wheels, Tires, Suspension 2 21 Oct 2016 07:24 am
Severe Front End Vibration 05PTGT Wheels, Tires, Suspension 14 19 Mar 2011 10:35 pm
Front End Knocking and Vibration arnsc Wheels, Tires, Suspension 11 10 Mar 2011 03:34 pm
Vibration in wheels KingKole02 Tech & Performance Forum 6 29 Oct 2004 04:03 pm
Front end vibration TexJon General PT Cruiser Discussions 10 14 Nov 2003 01:05 pm
