Wheel bearing replacement
Like Tree4Likes
  • 1 Post By jcraft
  • 2 Post By Tuggajb
  • 1 Post By raeder
Old 31 Jul 2020, 12:05 pm
Default Wheel bearing replacement
Hi All,
Looking at replacing my front driver side wheel bearing on my 2002 PT cruiser as it is bad. I did the same one about 10 years ago so its not difficult from what I remember. Back then though, once I removed the hub assembly I took it to a local shop and they pressed the old out and pressed the new one in. I am going to do this next week and this time I have access at work to a small manual 10 ton press. I am wondering what the steps/precautions are to pressing the old out and then pressing the new in. I may attempt myself if not to difficult but I have heard that there are serviceable and non serviceable hubs and the latter is much more difficult to press out bearings and mechanics usually refrane from doing it. Not sure what types is on the PT cruiser. Any help will be appreciated. Thx
raeder likes this.
Old 01 Aug 2020, 06:44 am
Default Re: Wheel bearing replacement
Originally Posted by jcraft View Post
Hi All,
Looking at replacing my front driver side wheel bearing ... I have heard that there are serviceable and non serviceable hubs and the latter is much more difficult to press out ... Not sure what types is on the PT cruiser.
Depends on what your definition of non serviceable is. On my 04 one of the hubs had wear from the bad bearing. Replaced the bearing and hub. If I didn't, the new bearing wouldn't have lasted very long.
It's been a couple years, but as I remember, the tricky part was removing the inner bearing race from the hub. I cut a groove in it then cracked it with a chisel.
Old 01 Aug 2020, 08:12 pm
Donít forget to install the ground strap or you will ruin the new bearings as static electricity pits the race and there goes your new bearings
Old 02 Aug 2020, 08:54 am
MJKnight's Avatar
Just remove the knuckle
And take it to your local
Shop..
They press in and out..
I've done several, , it your best
bet...
Old 03 Sep 2020, 02:11 am
Hi All,
Have you successfully done it yourself? My buddy's uncle got a manual press and it is not a small one. I'll see it's capacity. My buddy took a new TJ as a weekend toy project we'll work after we finished installing the brake pads and vision wheels on the truck and clear the garage. We may try to use the press soon.
rockandroller likes this.
Old 01 Nov 2020, 05:06 pm
Happy's Avatar
I have a press to pop them off but I have a bearing heater...it expands the bearing and slips right on, let it cool and your good to go.
03'PT Cruiser GT electric blue
Wheel Bearing Replacement Shortcuts? Matt42 Tech & Performance Forum 10 25 Dec 2012 04:36 am
Wheel Bearing Replacement Poncho Villa Tech & Performance Forum 35 10 Jun 2012 07:09 am
wheel bearing replacement? clark200 Wheels, Tires, Suspension 1 17 May 2012 08:39 am
Wheel bearing replacement problems....need help srebik Tech & Performance Forum 7 26 Mar 2012 01:41 pm
Wheel Bearing / Hub replacement parts soccrstar Tech & Performance Forum 0 27 Mar 2010 02:48 pm
