Hooligan,
Since you think you can change the pads yourself and save money, why not take the rotors off also since it's only a couple more steps and take them to a shop to have them turned down. Shouldn't cost very much since you did all the work for them.
Unless you have a pulsing in the pedal when you hit the brakes hard, just put in the new pads. I did, at more miles than you, and I now have about 77,000 on the PT overall. I'm replacing rotors next pad change. The rotors aren't that thick to begin with and turning takes away some thickness. MY OPINION.
That is what I figured when he told me that. I'll plan on changing the rotors next time, unless a pulsating shows up before then.
In reading the instructions, it mentions using a "C" clamp to compress the actuating valve to force the brake fluid back to the fluid container, any one have a idea what size clamp can be used? The PT is our only driver and I need to know all the answers befor I get started. I was trained as a diesel machanic in one of my other lives in the Coast Guard, so have the skills, (not many brakes aboard boats!!! not all of the answers. |
Hooligan,
You might not have to use the "C" clamp as the old pads might be able to come out without compressing the valve, but if you do need it, the clamp only has to open about 3 to 4 inches or less.
When I did mine I used a 4" C clamp and a small piece
of 1 by 2 put it over the cylinder.or you can use the old brake pad.I'm with Don on not turning the rotors.Be sure to take the cap off the fluid container before pushing the cylinder in and don't forget to put it back on.
04 cool vanila Limited Turbo ![]() Wife has a 03 limited (Steel Blue) |
I go slow on turning the C-clamp in (use biggest c-clamp I have - 6"?) because I have ABS and don't want to screw up controller. |
[quote]quote:Originally posted by quicksilverdon
forget the clamp and just use a pair of channelock pliers. Took me 10 mins a wheel to remove and replace rotors and pads. Of course, Ive done it before......[:I]
<font color=\"purple\">214whp/246wtq</font id=\"purple\">
| Lomandi Brake Pads and Rotors | CHROMEDCRUISER | Wheels, Tires, Suspension | 5 | 24 Feb 2010 06:29 pm |
| Disc Brake Pads and Rotors . | Rich Slider | Tech & Performance Forum | 18 | 13 Jan 2006 04:27 pm |
| Brake kits for the Pt Gt from Moparsupercenter.com | JEFF@RHJEEP | Vendors & Buyers Forum | 0 | 23 Apr 2005 01:07 pm |
| Brake Rotors | mcruz | Turbo Wheels/Suspension/Handling | 5 | 24 Feb 2004 07:51 pm |
| Factory brake rotors cracking already (under 30k) | braindead0 | Tech & Performance Forum | 6 | 30 Sep 2003 04:38 pm |
