PT Cruiser Forum Car Videos
Custom Wheels
Steel Wheels
Old 13 Sep 2004, 05:51 pm
Blackcruiser Blackcruiser is offline
Default Steel Wheels
Does anyone know if you can run 16" Chrysler steel wheels on a 2003 GT cruiser ?[:I] I have 17" wheels on the car right know, but I know that there maybe an issue with the clearance of the front brake caliper. TIA
Old 15 Oct 2004, 05:09 pm
OurPTGT OurPTGT is offline
I'd like to know also. I'm wondering if the peeps with drag radials are using 15" steelies [:I]
bump
Old 17 Oct 2004, 10:28 pm
Basset Hound Basset Hound is offline
You are correct. The 16" wheels won't fit a GT because of the bigger brakes needed to compensate for the extra speed of a GT. I don't know of anyone who is making 17" steel wheels.
Enjoy the cruise.
Don aka Basset Hound
Pics at: http://members4.clubphoto.com/don284358/
Old 05 Nov 2004, 09:37 pm
idigrocks idigrocks is offline
You can use 16" steel wheels or even 15" but you have to add spacers behind the wheels (over the wheel studs) to make up the wider offset required by the GT calipers (front wheels only). I run 4 snow tires on OEM steel wheels in the winter with no problems on my GT. You can buy spacers at PepBoys or similar, or stack a couple of half inch steel washers on the studs to make up the width. Don't forget to get the correct tire size if you want your odometer to read true. The size for 15" is 195/65.
vB code is On
Do "KLEEN WHEELS" really work??? Gary04GT Wheels, Tires, Suspension 14 26 May 2008 03:37 pm
Using bigger wheels lcuadrado Tech & Performance Forum 16 24 Jul 2007 01:06 pm
SRT-4 Wheels on the GT blueberrygt Turbo Wheels/Suspension/Handling 3 13 Apr 2004 06:45 pm
Lets talk Wheels turbomangt The Detail Shop 2 05 Feb 2004 02:10 am
Steel Wheels for Winter Tires shredney Exterior Accessories Forum 3 26 Oct 2002 04:17 am
  Personal Finance | Internet Advertising | Debt Consolidation | Online Advertising | Mortgages
