40mm offset work?
Old 20 Oct 2004, 10:20 pm
Default 40mm offset work?
I'm looking at the Enkei Arashi rims, but they're a 40mm offset.
Does anyone know if they will work on the GT?
http://www.enkei.com/PerfSpecPAGES/arashiSpecs.html
Paul
Old 21 Oct 2004, 01:32 am
I'm running 42mm offset so 40mm is no problem.
http://www.cardomain.com/memberpage/504007
<b><i>Dream Bruizer DC1 #632</b></i>
Old 01 Nov 2004, 05:28 pm
I think my wheels are 40mm offset and I need spacers in the front [:I]
Old 02 Nov 2004, 02:12 am
I have Gianelle 10 Flush that have a 35 mm offset and have no problems. The stock 01 and 02 Limited rims are a 40 mm offset. Anything between 35 to 45 SHOULD work but always test fit any rim before it's mounted. If memory serves me correctly the lower the offset the further the rim is set out towards the fender. You wouldn't think 5 mm work make much difference but I'm running Yokohama AVS ES 100 tires witch have a pretty square sidewall and the difference in appearance is dramatic
Greg Gavencky
The New Jersey Cruisers
www.njcruisers.com
17x7 & 18x7.5 w-40 offset KingKole02 Wheels, Tires, Suspension 0 19 Nov 2006 12:42 am
18x8 Konigs 40mm Offset on Eibach Car ? TripleJackInGA Turbo Wheels/Suspension/Handling 4 10 Jun 2004 11:22 am
GT Wheel Size & Offset jramosGT Turbo Wheels/Suspension/Handling 2 16 Apr 2004 11:25 pm
18x7.5 40mm offset wheel/tire pics? TripleJackInGA Wheels, Tires, Suspension 1 20 Feb 2004 12:33 am
Prison or Work? You decide... Gary04GT Non-PT Discussions 1 29 Jun 2003 04:09 pm
