Energy Suspension Bushings
Old 08 Nov 2004, 04:04 pm
Default Energy Suspension Bushings
Has anyone else put on the Energy Suspension ft sway bar bushings?
Were you able to torque the end links to 28Nm as per the spec for the OEM part?
Thanks,
Andy
Old 09 Nov 2004, 05:10 am
If you use aftermarket polyurethane bushings for the Front End Links, you will not be able to use that torque setting. The OEM bushings are made of hard plastic (which is why the torque setting will work), plus the "nut" is made of stamped steel. So you end up with 2 problems. One is determining how tight to tighten the "nut" and two, how to take off/reuse that "nut". It would be easier to buy new end links, they come in different sizes/lengths and include the bolts, nuts, washers, and spacers. If you are staying with the stock front sway bar, then measure the total length before your take it apart and buy replacement end links that come the closest. Can look at this page near the bottom to see the available lengths:
http://www.addco.net/install.shtml#together
You won't be able to see/notice the polyurethane bushings "bulge out to the edge of the washer" as most aftermarket instructions (bushings only and anti-sway bar packages that include replacement front end links, bushings, washers and spacers) say as being the optimal/final tightening sequence. I would suggest tightening the bolt/nut until you see enough threads to put on another nut. I usually buy self locking nuts at the local hardware store to ensure the nuts don't back out or get loose over time and in most of the aftermarket anti-sway bar (front) installs we did on my friends PT's, used 2 nuts (the supplied nuts and add a locking nut on top).
Old 09 Nov 2004, 10:02 am
Hi Sci-Fi,
The kit came with with new bolts, self-locking nuts, washers, spacers and bushings. The people at suspension.com said torque it to mfg specs or as tight as I could, whichever came first. So I tighted it down some more last night. The wrench eventually clicked at the prescribed torque, so I'm going to go with that.
PS: Thanks to your web site, I got the large Mobile 1 oil filters now.
Jumping PT suspension ?? Ctown Turbo Wheels/Suspension/Handling 7 24 Apr 2005 06:38 pm
Finally Energy Suspension kit installed+result Ctown Wheels, Tires, Suspension 4 02 Jan 2005 03:53 pm
got my Energy Suspension Hyper flex kit Ctown Wheels, Tires, Suspension 10 31 Dec 2004 02:00 pm
Anyone running the MP suspension? sca037 Wheels, Tires, Suspension 5 17 Jun 2004 01:41 pm
Autocrossing with air suspension renichms Tech & Performance Forum 2 12 Apr 2002 10:29 am
