Wheels and Speedometers
Old 08 Nov 2004, 04:31 pm
Default Wheels and Speedometers
I've been reading about people's wheel upgrades to larger diameter sizes. Has anyhone had to get their speedometer recalibrated after making a wheel swap? A change in diamter can throw off the speedometer. I'm wondering how far you can go without affecting the reading?
Old 08 Nov 2004, 05:06 pm
On these cars you can not get your speedo recalibrated. This site will tell you the difference in speed
http://www.miata.net/garage/tirecalc.html
On my GT when I went from factory 205/50-17 to 205/40-17 my speedo is now 6.4% too fast. At 60 mph I am actually doing 56.1 mph. I just compensate with a 4 mph difference. You can adjust going to a bigger size tire by going to a lower profile tire if you want, in other words if I went to a 205/40-18 I would only be reading 2.4% too fast and going 58.5 mph instead of 60 mph. You can play with the numbers and see what you want.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 08 Nov 2004, 06:12 pm
I went from the OEM size 205-55-16 to a larger 205-50-17. My speedometer is reading .08% too slow so when it reads 60 mph I'm actually doing 60.5 mph. Not enough to worry about.
Old 08 Nov 2004, 08:35 pm
Your reports are good news. I'm still thinking of going with the full moon disks from Speedway Motors. If I did I would like to put a tire with taller side walls per "back in the day." It sounds like it wouldn't throw things off too far. Crewzin I like the how the wheels look on your car.
Kevin
