Carey,
You may just want to leave it alone. However, if you like me it will bother you even if you don't see any differences.
KingKole02 ![]() SW Florida PT Cruisers Secretary/Treasurer/Webmaster www.swfloridaptcruisers.com Just Cruisin, 03 N/A auto. TE Steel Blue w/ pearl coat & chrome package. Too many extras to list, see pics For my story and cruiser pics go to: www.kingkole02.com Other pages I have: http://www.ptcruiserweekly.com |
crewzin.
you can do it yourself for free and all you'll need is an alignment for the front camber only ($50) the eibach kit consists of only 2 bolts with a cam lobe on it so when the bolt is rotated it moves the steering knuckle. the eiback kit for the pt cruiser is only $29.00 for BOTH sides. it replaces the upper bolt on the lower strut mount where it attaches to the steering knuckle. -.5* more of camber can be a good thing for better cornering. thats how i have mine set up with the alignment kit. Personally i would also just leave it alone as it is the same on both sides.
www.cardomain.com/id/rallydrock |
OK, Colby, your right it does nag me a bit. In fact, I took RallyDRock's advice and went on-line to "Drive Wire" and they had the PT Cruiser Eibach Alignment Camber Kit on sale for $20.80 plus $4.95 for shipping (kit is for both front wheels). So I guess I'll have something to do when it arrives. Thanks.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. 100,000 miles, Original Owner Visit My Home Page www.CREWZIN.com |
Actually the Eibach kit is a repackaged Ingalls Engineering Camber adjustment bolt kit. Just look at the part number (81260) and adjustment range +/-2°(actually its 1.75°). They are the same and many companies repackage Ingalls camber bolt kits. The only one that is different is H&R's "Tripple C", part #TC114, which offers adjustments +/-3°. Could probably go to a local auto parts store and ask for a pair for a 2002-2004 Altima, 1995-2003 Maxima, 2001-2002 Honda Civic (not the SI model), 2001-2004 Insight, Hyundai Sonata, etc, or just give them the Ingalls part number and it will work. $20 is the going price for the kit for both sides.
2002 Almond Pearl Limited Edition 27K It\'s nice to be important, but it\'s more important to be nice. http://sci-fi.ptenthusiasts.net/
Thanks Si-Fi. At least I didn't get ripped off by the dealer who wanted $23.50 for each bolt [:0] although I had to pay for shipping, in the long run I saved a bunch. It sounds easy enough to install these bolts....I wonder why the dealer wanted 1 1/2 hours to install them. [:I]
You're paying for the alignment plus labor to install the camber kits. As a D.C, tech who specializes in front end work I'lkl tell you that as long as camber doesn't go more than -0.5 degrees don't worry about it. I have found that lowered cars like a little negative camber. When you go past that you may run into tire wear problems unless you are real good about tire rotations.
Just my 2cents worth |
Thanks for your input ($.02). What I was referring too was the dealers price of $23.50 per bolt when my on-line purchase, and Si-Fi's input, put the price at about $20.00 for a set, plus 1/2 hours of labor to install those two bolts. The 4 wheel alignment (which I was told that I'd need after the installation of the bolts was another $98 on top of that.
I am "real good" on both oil changes and tire rotation on all my cars. Every 3K. That's probably why I never did see any abnormal wear on the tires, but the -.05 does bother me so I'll try to get it as close to specs as possible.
Wow Crewzin you rotate your tires every 3000 miles. I am
impressed.I rotate the tires on both Cruisers twice a year. spring and fall.when I change my wheels for summer and than for winter,
04 cool vanila Limited Turbo ![]() Wife has a 03 limited (Steel Blue) |
