I got the wheel back while my car is driving on the donut spare. It doesn't look bad. I'm thinking I'll put it back on the car, and if it holds air I'll leave it there until I can find a used wheel through a junk yard or something.
I'm still considering getting a whole new set of 17 X 8 or 17 X 7.5 wheels and then putting Michelin Pilot Sport A/S tires on them, but that's still a lot of money. 4 Wheels X $230 = $920 4 Tires X $200 = $800 Total = $1,720 It's still cheaper than the two rims and 2 tires originaly proposed, but it's a lot of money by my standards.
Joe R - 2003 Electric Blue PT Cruiser GT Turbo ![]() http://www.pbase.com/robinjoe/pt_cruiser |
Thanks to everyone for the input. I've decided to get a new set of rims and tires from Sears.
Wheels: 17 X 7 WHL AR606 http://tinyurl.com/587vq Sears recommended the Sumitomo HTR+ $120 But I'm considering the Continental ContiExtremeContact instead Then I'll sell my two good rims on line.
Looks like a good choice. I think you will be happier with the wider wheel.
2003 Almond GT AutoStick, body colored rear splash guards and hood struts, chrome gear shift, AC & vent knobs, billet steering wheel spokes and pedals, AMX1397 Turbo-Intake Pipe. |
I see that you have discovered one of the best kept secrets - Sears has the lowest prices on CHROME wheels with many styles to choose from for under $600 a set. Some of them are even on sale this week for $520 (their SSC brand)! I can't make up my mind between the Casino, Aero, Fusion, or Type SR. I'm leaning toward the Casino Chrome style.
2003 PT GT Auto w/Stage 1 |
New wheels and tires were installed yesterday. When they gave us the car back the Sears mechanic asked me if the car was making a thunking sound when I brought it in. It wasn't.
He told me it was probably just a little dirt on the brakes and that it would go away. I asked him to take it back in and clean it up to make it stop. He did, but the clunking was still there. He took it back in and cleaned the rotors and adjusted the hand brake. The clunking has been greatly reduced, but is still troublesome. The clunking only happens when I'm braking, and slows as the car slows. Seems to happen with each tire revolution. Any clue as to what might be causing this? Is it safe to do as the mechanic suggested, and just drive it until it goes away? I'm thinking of bringing it in to another shop to get a second opinion.
There is very little clearance between the wheel and the brake. If the offset of the wheel is wrong you could have a rubbing there. If the caliper is almost touching, you might get a little rubbing when you apply the brakes. Just a thought.
Like MichaelDay said, one or more of the wheel spokes may be contacting the brake caliper. If you can tell what wheel is making the noise you could take it off to visually inspect the back of the wheel and the caliper for signs of rubbing. If you're lucky, you may even be able to inspect the caliper with the wheel still mounted and find a place where bright metal showes up from the rubbing.
A bit of grinding or filing may be all you need or perhaps a spacer on the hub. In any case, get a little dirty and give yourself the pleasure of solving this issue. ![]() I just re-read your original post. Rotors, spindles, wheels and such can be bent by impacts such as potholes. This can cause a pulsing noise when braking. If you have your wheel off, spin the rotor and look for runout of the rotor. If you can detect the caliper moving slightly in and out then you have a bent rotor. |
It may also be that the guy bent the rim when he installed them, though he may never admit to it. I would check the inside for clearances.
2002 Inferno Red PT LE (Auto), Blane Hood Struts, 3rd Brake Light sign - SERENITY AirAid Intake, Chrome Taillight covers - more to follow |
| Do "KLEEN WHEELS" really work??? | Gary04GT | Wheels, Tires, Suspension | 15 | 12 Oct 2008 07:44 pm |
| Using bigger wheels | lcuadrado | Tech & Performance Forum | 16 | 24 Jul 2007 01:06 pm |
| SRT-4 Wheels on the GT | blueberrygt | Turbo Wheels/Suspension/Handling | 3 | 13 Apr 2004 06:45 pm |
| I don't like my new wheels | coolvirus | Turbo Wheels/Suspension/Handling | 5 | 05 Mar 2004 06:14 pm |
| Lets talk Wheels | turbomangt | The Detail Shop | 2 | 05 Feb 2004 02:10 am |
