Whats the bore of the hub in mm?
Old 08 Mar 2005, 06:29 pm
Send a message via AIM to Supercharged
Default Whats the bore of the hub in mm?
I need to know this so, so I can get some hub centric rings. Because my aftermarket wheels whobble even though they are fully tight..
Thanks
Steven
Old 09 Mar 2005, 12:30 pm
On my old wheels, the guy told me the car was 57.1
Old 25 Oct 2005, 09:20 pm
ok, well, now that I found this post..
57.1 is right??
98 Grand Prix GTP
Mods-I have some
01 PT-Pimpin it our for Mom
[IMG][/IMG] 01 PT
Pimpin it out for mom
Old 28 Oct 2005, 09:39 pm
I'd like this info also for the same reason [B)]
Old 08 Nov 2005, 10:56 pm
OK, I orderd the rings
The hub size in around 57.15mm like purple04 said...
Thanks again guys
98 Grand Prix GTP
Mods-I have some
[IMG][/IMG] 01 PT
Old 09 Nov 2005, 02:17 pm
Did you guys make sure the retaining washer was removed when you put your new wheels on ??? Had the same wobble and all I had to do was remove the retaining washer from the one stud and the wobble disappeared.
<b>\"The only difference between a man and a boy is the price of his toys \"</b>
Old 24 Dec 2005, 03:35 am
No, there wasnt a retaining washer with these rims
Well, we finlly got the Hub Centric Rings on and it made a huge difference. No wobble no more
98 Grand Prix GTP
Mods-I have some
[IMG][/IMG] 01 PT
Old 03 Jan 2006, 03:23 pm
I had a vibration problem with aftermarket wheels. Try to torque the wheels. Air wrenches don't do a good job. My winter wheels were balanced 5 times and it still shook. A friend put ceramic brake pads on for me and used the proper torque on the wheels in the proper order and no more shake. Most of these tire stores have no clue how important it is to get the wheels centered. The rings aren't always the answer. If the wheels are correctly balanced the proper torque will take care of the problem.
Greg Gavencky
The New Jersey Cruisers
www.njcruisers.com
Old 07 Jan 2006, 02:17 am
The rims were always torqued to 100 ft/lbs.. Never made a difference
quote:.Most of these tire stores have no clue how important it is to get the wheels centered
See, that is the problem. That’s what the rings do. They center the wheel. With the Inner bore of the Aftermarket wheels being bigger then the bore of the wheel hub, the wheels can never be centered properly. That’s where the hub centric ring comes into play. It takes up that empty space between the wheels and hub to center the wheel.[?]
98 Grand Prix GTP
Mods-I have some
[IMG][/IMG] 01 PT
WHAT IS THAT NOISE??!! inferno General Turbo Discussions 7 18 Oct 2006 03:16 am
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
tapping elacua General PT Cruiser Discussions 3 27 Mar 2006 06:53 pm
Throttle Body Bore proxeyed Tech & Performance Forum 1 04 Jan 2005 12:11 pm
Engine "tapping" Noise. EJIII Tech & Performance Forum 3 03 Jan 2005 01:32 pm
  Debt Consolidation | Wordpress Theme | Free Music Download | Golf Jyouhou | Wordpress Themes
