bigger wheels
Old 11 Mar 2005, 09:33 pm
Default bigger wheels
I have an 05 GT with 17" wheels which I really like but........ I installed sidepipes and have drastically reduced my ground clearance, most speedbumps are no longer an option. if I go to a 19" wheel I know about the performance factors and speedo being off, but will the tires rub? If they do I guess I will just have to avoid speedbumps 18" wheels would only give half an inch more clearance and that won't justify the expense
Old 11 Mar 2005, 09:37 pm
Send a message via AIM to TaylorMade
buy a 4" lift kit for a dodge truck. Find some way to make it fit the pt, and swap out the suspension. Should be pretty easy. []
2001 limited edition midnight blue PT, 17\" enkei wheels, rear spoiler,silencers removed, k&n drop in filter,MX-5\'s 1-2 burp-free shift mod, 1 10\" subwoofer, and a Dynomax muffler. (Just a 17 year old who loves his car)
Old 11 Mar 2005, 10:19 pm
Its not quite as simple as you're suggesting, mooniac [8] You also have to look at the aspect ratio. That gives you your final overall diameter or tire height. [8D] Perhaps you could even find a suitable tire height keeping your 17" wheels.
PTurbed
Old 13 Mar 2005, 08:13 pm
i acutally just got 19*8 wheels with a 40mm off set wiht 215/35/19 bfg tires, they wil fit fine, yea the tires are like rubber bands but i dont want beefy tires i needed something small so my pt would sit lower, but once the wheels are on ( which willl be tuesday) ill post some pics
\"You All Laugh Because I\'M Different, I Laugh Because YOU\'RE All The Same!\"
Do "KLEEN WHEELS" really work??? Gary04GT Wheels, Tires, Suspension 15 12 Oct 2008 07:44 pm
Using bigger wheels lcuadrado Tech & Performance Forum 16 24 Jul 2007 01:06 pm
Lower MPG with bigger wheels? Gunner Turbo Wheels/Suspension/Handling 13 27 Oct 2004 02:47 am
SRT-4 Wheels on the GT blueberrygt Turbo Wheels/Suspension/Handling 3 13 Apr 2004 06:45 pm
Lets talk Wheels turbomangt The Detail Shop 2 05 Feb 2004 02:10 am
