| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
I've been thinking of changing rims/tires to 18"x8" or just tires to 225/45s. I was talking with someone who replaced the stock 205/50s with 225/45s on the stock 17" rims. He said you feel all bumps harder and is thinking about going back to 205/50s or 215/50s. Anybody else feel this way? If they did this is the traction/feel on cornering better?
I went to 40 series tires and though the ride is a tad rougher over bumps I wouldn't trade the great handling for big porker tires. I'm sold on low profile tires. [8)]
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
The cool thing is, you can "build" them how you like them. I like my tires and wheels to be cushy and quiet on the road but take off like a raped ape in a straight line when I want. Others want to cut a corner like the they're on rails and others want to stuff in as big a wheel as posible for extra bling.
I'm very picky and I'm still searching for my perfect wheel and tire. I like the look of my stock Turbo wheels for now but they are too narrow and will someday be changed. An Ol' School, Hot Rod look is what I'm going for so most of the newer style wheels that have a high tech, edgy look, won't work for me. This is one of those things that are not "one size fits all". The more you study up on it and the more you try different set ups, the more you will understand the trade offs and know what fits you best. |
Jeff-
The fellow is right - The lower the aspect ratio - the number after the slash - the less rubber between the rim and the road, so less ability to absorb shocks - you get better handling because the tire is wider, but you also run the risk of losing a rim in a pothole.[:I]
\'05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler, E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5\", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in \'02 Silver Touring Edition w/87,000 miles |
QSD,
Your reply on the aspect ratio is both right and wrong. Let me explain: If you are comparing the same treadwidth to different aspect ratios, i.e.: 205/50 to 205/40, then yes, you are correct about less sidewall rubber between the rim and the road. However, if you were comparing 205/50 to a 235/45, then the 235/45 tire actually has MORE sidewall rubber between the rim and the road. Scott
\"If you choose not to decide, you still have made a choice.\" |
And if you go to larger rims, you will be guaranteed to have less rubber - it keeps me from 17" rims. ![]() |
After a lot of soul searching I am going to buy my new tires at Costco and get Bridgestone Turanza LS-V in size 225/50 for $167 per tire minus the mail in rebate of $25 per tire. I like Costco over Tire Rack cause they sell the tires complete with road hazard guarantee, free rotations, balanced, rubber stems, and mounting. They also use nitrogen which is nice. I have to go with the larger width to get the load rating on this tire as I do not want to loose any GVWR. I talked to the technical people at Tire Rack and was assured this size tire would fit on my 6" 17" rims. The revolutions per mile will go from 833 to 807! The larger sized tire also adds about 4 lbs per tire.
06 GT Auto, Cool Vanila Exterior, Presto Change O 3bl, Cargo Mat and Net, Billet Oil Cap, Yoko Avid 4Vs Tires, 03 GT Wheels, 4 Chrome Door Handle Screw Covers, MOPAR Mud Flaps, H&R Rear Sway Bar, Freedom Strut Tower Bar, Rear Door Sill Covers. |
Steel, it sounds like you did a thorough study on your tire upgrade. Thanks for posting your thoughts and results, like the rotations per mile and weight. This is a good example of many of the variables each person should consider when choosing tires. It does go beyond the govt ratings for temp, tread wear and season ratings.
2004 Dark Plum Base with windows tinted, cabin filter, silencers removed, fog lights, 18\'s, all Red taillights, Blaine\'s struts, modesty cover, color-matched center dash, 06 rear bumper |
