Wheel and tire info and pics
  #11 (permalink)
Old 15 Apr 2005, 08:51 pm
bruent's Avatar
235/40/18 Motegi DPK's w/Capital Negotiators, no problems here. Have been on some long trips to shows on all sorts of roads in differant States.
  #12 (permalink)
Old 21 Apr 2005, 03:56 pm
IVE GOT BFG TIRES AND THERE AWESOME IM RUNNING 235/15/19 ON A 19X8 WHEEL
\"You All Laugh Because I\'M Different, I Laugh Because YOU\'RE All The Same!\"
  #13 (permalink)
Old 23 Apr 2005, 01:31 am
PTchickie, can you make the photo a bit bigger? I can't quite make out the shirt color on the mountain climber.
  #14 (permalink)
Old 23 Apr 2005, 10:46 am
Opie, as someone has stated. You need to submerge them in water. But, just putting in what I know about your type of rims( I deal with high brand rims quite often) are. I would say you have metal valve stems correct( not metal sleeves over rubber stems)? Those metal stems bolt to the wheel. They are threaded, you stick them through the wheel & tighten them down with a nut. They also have 2 rubber washers on both sides of the rim. These rubber washers are known to go bad quite often & rather fast. They are a pain in the "you know what".
If someone put the tires on improperly they can hit the stem & it will flex causing the washers to either crush & rip or could completly remove them. That would be obvious because the stem would flex.
Also IF you have the rubber stems on there. That could also be the problem, as these types of rims do not fair well with rubber stems.
  #15 (permalink)
Old 23 Apr 2005, 11:23 pm
My Base 04 came with 16's and my wife's 04 Touring came with 17. I'm not going any bigger because I have heard from some that the ride is just not as good with bigger wheels. Others say they're great. I don't like the look that much to take a chance and not like the ride. Actually would like to get Smoothies, but don't have the money for that right now either. I've taken both on some long drives (900 miles) with the stock wheels, and so far I'm happy with them. 12K miles on the Base model.
  #16 (permalink)
Old 23 Apr 2005, 11:30 pm
lol sorry jeff i have no idea how to resize lol [:I]
  #17 (permalink)
Old 24 Apr 2005, 10:41 am
PTChix,
Is this the latest pics with the new suspension mods..looks like your running 19's on all four? get back at me Kevin..
  #18 (permalink)
Old 24 Apr 2005, 10:06 pm
HI OPIE
From my experience with these tires, they are very tricky to mount to the rim. one mistake could tear the bead which is how it seals to the rim. i had some mounted and it went flat over night.
but i do have some stock GT wheels with tires for sale BUD
http://www.cardomain.com/memberpage/729184/8
  #19 (permalink)
Old 28 Apr 2005, 05:05 am
YEAH KEV THOSE ARE THE LATEST PICS
  #20 (permalink)
Old 28 Apr 2005, 10:00 am
PT CHIX,
So give some details on what was done with the suspension and what are the specs on the wheels?
Kev
Need help for the right 17" tire size! 1lowufo Wheels, Tires, Suspension 8 06 May 2005 12:32 am
Chrome and Pics BumperBob General PT Cruiser Discussions 1 11 Apr 2005 12:58 am
