question on front rotor replacement?
Old 03 May 2005, 07:19 am
gonzomania's Avatar
Send a message via AIM to gonzomania
Default question on front rotor replacement?
If anyone has replaced the front rotors on their 2003 base PT I have a question. Is there a wheel nut(what size?) or screws that hold the rotor on or will it just pull off? Starting job in a couple of hours after I pick up parts. Just wondering if any other special tools needed?[:I]
Old 03 May 2005, 07:49 am
There's usually a metal retainer clip/washer on one of the studs that you need to remove/unscrew with a pair of pliers. It is not necessary to reinstall it.
Just FYI:
It's put on there from the factory to hold the rotor in place during assembly and the factory wheels are designed/machined to provide the necessary clearance so the wheel is flat against the rotor. And it's also the cause of many vibration problems for those that buy aftermarket wheels and don't remove the clip/washer.
Old 03 May 2005, 08:00 am
gonzomania's Avatar
Thanks SciFi
Old 03 May 2005, 12:40 pm
gonzomania's Avatar
Haven't done a brake job in may moons. Took about 3 hrs (I didn't want to run into Gonzomania). Pads were really worn. Cut into rotor on passenger side, so I had to replace them but should be good for quite some time. I kept thinking the scraping noise was from the rear drums. I put ceramics on.
Old 03 May 2005, 12:51 pm
Sci-Fi (as always) is right on.
No special tools, except big C-clamp to push piston in so you can get caliper back on.
Please help, front end shimmy survey Boomer Tech & Performance Forum 32 05 Oct 2009 01:54 pm
Front Control Arm Bushing Question JohnM Wheels, Tires, Suspension 6 26 Aug 2005 11:40 am
Front grill question... smfrycruzr General PT Cruiser Discussions 5 13 Jul 2004 10:01 am
Question after installing speakers in front doors wyzard Sound and Security Forum 3 09 Apr 2004 01:10 am
Jody , I have a question about your front bumper OC CRUZER Exterior Accessories Forum 0 19 Nov 2001 08:54 pm
  Wordpress Theme | Expekt bonuses | Debt Consolidation | Business Gifts | Debt Consolidation
