2.5 drop and 17 inch rims
Old 07 May 2005, 07:58 pm
Send a message via AIM to AlexAlex
Default 2.5 drop and 17 inch rims
What the biggest size tire/rim size I can go with when my pt is dropped 2.0-2.5inches low? All I know is I had 18's on my sunfire and it was only dropped 1inch.
Old 08 May 2005, 04:38 pm
You can go as large as 19" rims with 235 tires, but you have to get the right offset for them not to rub on the inside or use spacers. I even read somewhere that 245 tires will work with the right rims, but that's really pushing it for the space and I would think some experimenting would be neccessary for a proper fit. There are some guys running air ride (big drop) and 19" rims. The rear has much more space and 20" rims will fit with 245 tires on the correct offset. You may even be able to go bigger on the rear if you really want a pronnouced rake in your PT. However you will probably have to special order a set of matching rims in 2 different sizes with matching tires in 2 sizes making it much more costly.
05\' GT Convertible in Metallic Midnight Blue
Mods...
http://www.cardomain.com/memberpage/808143
Please see Forum Guidelines regarding signature image sizing.
K&N DROP IN OR AFTERMARKET AIR INDUCTION? Crimson Tech & Performance Forum 11 16 Sep 2009 06:05 pm
19's and eibach sport spring drop superjes001 Wheels, Tires, Suspension 2 24 Feb 2006 06:59 pm
one inch springs. Jacked Up PT Wheels, Tires, Suspension 16 25 Sep 2004 12:44 am
K&N drop in a waste of time? Blue Streak Turbo Performance 8 09 Mar 2004 03:41 pm
18 inch wheels WUWU20 Tech & Performance Forum 2 25 Feb 2002 09:05 pm
