PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   Wheels, Tires, Suspension (http://www.ptcruiserlinks.com/forum/wheels-tires-suspension/)
-   -   OEM springs differences? (http://www.ptcruiserlinks.com/forum/wheels-tires-suspension/9693-oem-springs-differences.html)
Ctown 25 May 2005 01:14 pm
are there any difference between all PT cruiser OEM springs?
Is the base/touring model same as the limited? and how about the GT is it different than everything else?
quicksilverdon 25 May 2005 04:31 pm
Not sure about GT, but the Touring suspension is 1" lower than base suspension.
The Touring suspension is on Touring and Limited Editions (except for '05, where the Touring Edition has base suspension!!!!!)
MX-5 25 May 2005 08:25 pm
There are many different springs based on the build of each PT Cruiser.
Here's a 2003 parts list:
[ZCC] Thru[ZRJ]= Spring Group Type‘s Found on Indvidual Vehical Sale‘s Code
1 6505 116AA 2 NUT, M14X2, Strut to Strut Rod
2 5272 226 2 MOUNT AND BEARING, Strut, Upper
3 5272 227 2 SEAT AND BEARING, Suspension Strut
4 SPRING, Front Suspension Coil
4656 523AB 1 [SDC, SDA, SDF] [ZCC, ZRC]
4656 524AB 1 [SDC, SDA, SDF] [ZCD, ZRD]
4656 525AB 1 [SDC, SDA, SDF] [ZCE, ZRE]
4656 526AB 1 [SDC, SDA, SDF] [ZCF, ZRF]
4656 527AB 1 [SDC, SDA, SDF] [ZCG, ZRG]
4656 528AB 1 [SDC, SDA, SDF] [ZCH, ZRH]
4656 529AB 1 [SDC, SDA, SDF] [ZCJ, ZRJ]
#5272 461AB 1 [SDE] [ZEA, ZTA]
#5272 462AB 1 [SDE] [ZTB, ZEB]
#5272 463AB 1 [SDE] [ZEC, ZTC]
#5272 464AB 1 [SDE] [ZED, ZTD]
#5272 465AB 1 [SDE] [ZEE, ZTE]
#5272 466AB 1 [SDE] [ZEF, ZTF]
#5272 468AB 1 [SDE] [ZEH, ZTH]
#5272 469AB 1 [SDE] [ZEJ, ZTJ]
5272 710AA 1 [SDC, SDA, SDE SDF] [ZCK, ZRK]
CHRYSLER PT CRUISER (PT) ————————————————————————— ————————————————————————— ————
SERIES LINE BODY ENGINE TRANSMISSION
H = High Line (Classic) C = Chrysler 44 = Four Door ECC = 2.0L 4 Cyl. DOHC DD5 = A578 5 Speed Man.
P = Premium (Touring) EDZ = 2.4L 4Cyl DOHC DGL = 4 Speed Auto., 41TE
S = Sport (Limited) EJD = 1.6L 4Cyl DDD = 5 Speed Man 21M5
EDV = 2.4LD 4 Cyl
EDJ = 2.2LD 4 Cyl
