PT Cruiser Forum Car Videos
Custom Wheels
Strut rod nut torque
Old 08 Jun 2005, 03:41 pm
Espresso Espresso is offline
Default Strut rod nut torque
ANyone knwo the torque value of it? Normally I go "good n'tight", but I would actually like to know the real value. All the local stores are out of the manuals.
Putting on the lowering springs tomorrow & it would be good to know what it is. The dealer "cant help me".
I did a search & came up empty.
Old 08 Jun 2005, 04:04 pm
SteelBlueGT SteelBlueGT is offline
Hope these help:
Ball Joint Stud Pinch Bolt 70 ft lbs
Hub Nut 180 ft lbs
Disc Brake Caliper Adapter Knuckle Bolts 77 ft lbs
Lower Control Arm Front Pivot Bolt 125 ft lbs
Lower Control Arm Rear Pivot Bolt 185 ft lbs
Stabilizer Bar Cushion Retainer Bolts 21 ft lbs (250 in lbs)
Stabilizer Bar Link Nuts 21 ft lbs (250 in lbs)
Strut Clevis-to-Knuckle Nuts 40 ft lbs + 90° turn
Strut Shaft Nut 55 ft lbs
Strut-to-Tower Nuts 25 ft lbs
Tie Rod Adjuster Jam Nut 55 ft lbs
Tie Rod End-to-Knuckle Nut 40 ft lbs
Wheel Bearing Retainer Plate Bolts 21 ft lbs (250 in lbs)
Wheel Mounting (Lug) Nuts 100ft lbs
Old 08 Jun 2005, 04:08 pm
quote:Originally posted by SteelBlueGT
Hope these help:
Hub Nut 180 ft lbs
Your awsome. Thanks alot. [^]
vB code is On
Upper Torque Strut Installed Mean Green Turbo Performance 1 24 Jan 2005 12:03 pm
Saying bye, bye to wheel hop rice_killing_GT Turbo Performance 13 07 Jan 2005 09:57 pm
January contest winners announced skylight General PT Cruiser Discussions 105 19 Feb 2004 02:39 am
BTG shock tower brace CHROMEDCRUISER Wheels, Tires, Suspension 15 08 Feb 2004 03:11 am
Strut bolts torque spec's? silky Wheels, Tires, Suspension 4 21 Jan 2004 11:17 pm
  Debt Consolidation | Loan | Remortgage | Broadband | Loans
