Thread: Brakes
Old 11 Jan 2003, 10:54 am
American flyer American flyer is offline
I've owned a lot of cars over the last 40 years and only 2 ever had brake noise. Both were the front disc brakes. Many OEM pads have a lot of metal impregnated in the pads and this will cause squealing. The brakes work fine but sound terrible. I replaced the OEM pads with good quality aftermarket pads and the noise went away. Under normal conditions brakes should make little or no noise. Sometimes after washing a car and letting it set for a while a light coating of rust will build up on the rotors. This will cause noise when you first start driving but will stop once the rust has scuffed off. If you are a brake rider your brakes may be worn past the wear limits. You should pull the wheels and check the wear limits and or replace the pads. Our PT is a year old now with no noise at all.
Silver L/E 5-Speed
