Old 20 Feb 2009, 01:54 pm
garyerrol's Avatar
garyerrol garyerrol is offline
Default Re: Problem Starting 02 PT Cruiser
First thought would be that you need to have the starter replaced. Probably have a solenoid that is every once in a while sticking for some reason. It could have something that the plunger catches on until you smack it with something hard that makes it let loose. Any number of possibilities. Are you sure the connections at the starter are nice and tight. If you had a loose cable, maybe when you hit it, it nudges the connections tight again for a while. Personally I'd take it to a shop that specializes in automotive electrical problems and let them figure it out.
2001 LE, Shale Green, Aftermarket Wheels, Shorty Antenna, AirRaid Cold Air Intake, Whelen Talons (amber/white) in front windshield, Whelen Talons (amber) in rear side windows, Tomar RECT25's (amber) and Whelen Slimlighter(amber) in back window. Kenwood TK-880H 45 Watt Mobile Radio, Antenex 3db antenna w/ NMO mount.
http://smg.photobucket.com/albums/v7...0PT%20Cruiser/
Ham: N9PTC
GMRS: WPQS324
