Old 09 May 2010, 07:36 pm
superpug666's Avatar
superpug666 superpug666 is offline
Default Re: sound not gone...
Originally Posted by CREWZIN View Post
Not sure of any "tricks" but if you can get under the car, grab the shafts and see if there's any play in either shaft. There shouldn't be hardly any. Check the boots on each end of each shaft too (#3, 6, 10 and 13 in the second picture). Look for a cut or tare that might let dirt get into the spider gears.
it might sound stupid, but is there a special way to check for play? i mean left/ right....frint to back...up and down....because i know its normal that theres a bit of play when you rotate it......
I drive an hybrid, it burns both gas and rubber!!!!!
To hell with all religions!
Yes my baby is stock, for now!
